What are take safe measures and precautions i have to take to connect to the satellite using the CC200A-LB successfully .Even i am unable to get the GNSS data from the satellite module the response from the module is like the
AT+QGNSS=10,10,“GGA”
ERROR
even though the same format is mentioned in the at commands module
What is your current firmware version?
Has your CC200A been connected to the satellite?
09:39:21.349 → AT+QGMR
09:39:21.349 → +QGMR: CC200ALBAAR01A05M04_01.002.01.002
09:39:21.349 →
09:39:21.349 → OK
this is the firmware version i am unable to connect to the satellite even when i send the GNSS commands it is throwing the errors for this
---->AT+QGNSS=10,10,“GGA”
for the above AT COMMAND i am getting the ERROR response from the CC200ALB
1)What are the environmental measures i have to take to connect to satellite?
2)I have the doubt with the satellite module firmware
3)Give me any previous work done by you about this module
I have sent the latest one to your email,pls try
Give me any document that tells about how to upload the above file into the quectel module CC220A-LB
I have sent the latest Qflash, you need to update by the MAIN_UART
Sorry to bother you I am new to this
But there are more files in the file
which one to upload
like
CC200ALBAAR01A05M04_01.003.01.003.bin
CC200ALBAAR01A05M04_01.003.01.003_UPG.bin
fw.cc200a
LC76GPANR12A03S.bin
cm4_log_str.bin
flash_download.cfg
partition_table.bin
bootloader.bin
da_uart_115200.bin
gnss_config.bin
these all the files that are there in the file you have sent which one i have to upload
please tell me in indetailed manner
