Im trying to set 10Hz Fix rate in LC29HAA module. I tried the following commands:
#Configure time rate
$PAIR050,100*22
#Save parameters
$PAIR513*3D
when i reset the module as the protocol spec specifies, i see NMEA messages every 500ms instead of 100ms (10Hz). But even when i send PAIR051 the module answers 100, but the messages are every 500ms.
$GNRMC,173855.200,A,XXX.637652,S,05839.936642,W,0.10,205.71,131123,A,V*02
$GNGGA,173855.200,XXX.637652,S,05839.936642,W,1,28,0.77,34.065,M,14.854,M,4B
$GNRMC,173855.700,A,XXX.637790,S,05839.936636,W,0.10,205.71,131123,A,V0B
$GNGGA,173855.700,XXX.637790,S,05839.936636,W,1,28,0.77,34.066,M,14.855,M,40
$GNRMC,173856.200,A,XXX.637916,S,05839.936606,W,0.66,159.85,131123,A,V0E
$GNGGA,173856.200,XXX.637916,S,05839.936606,W,1,27,0.79,34.066,M,14.855,M,44
$GNRMC,173856.700,A,XXX.638000,S,05839.936606,W,0.67,182.62,131123,A,V04
What could be wrong? the baudrate is set to 115200.
