Can't connect to any network with Quectel EC25
Hello All,
I cant get my Quectel EC25 to connect to any network, or even detect them.
My AT+COPS=? returns +CME ERROR: 3, what can it be? Below some outputs that may be useful:
AT+CGMR
EC25AFAR05A04M4G
AT+CSQ
+CSQ: 99,99
AT+COPS?
+COPS: 1
AT+COPS=?
+CME ERROR: 3
AT+COPS=1,2,“26801”
+CME ERROR: 30
AT+CPIN=?
AT+CPIN?
+CPIN: READY
AT+CFUN?
+CFUN: 1
ati
EC25
Revision: EC25AFAR05A04M4G
I have a SIM card that works fine in my smartphone and in a router i have, and i have also just plugged the antenna’s i received from Sixfab.
What can i do?
Thanks in advance
Try these:
AT&F0
AT+CFUN=1
AT+QPOWD=1
Tried it just now, but still the same.
Additionally, i did these commands as well:
aT+QNWINFO
+QNWINFO: No Service
at+csq
+CSQ: 99,99
at+cops?
+COPS: 1
at+cops=?
+CME ERROR: 3
Cant understand what is wrong!
Have you tried with a different SIM card?
Yes, i have tried with different SIMs, from diferent providers, all of them working in other devices
Do you realize that you are trying to use the North American model in Europe?
What frequency band do you think your modem will operate in?
Running the command at+qcfg=? it tells me that it supports all bands, is this not true?
at+qcfg=?
+QCFG: “gprsattach”,(0,1)
+QCFG: “nwscanmode”,(0-8),(0,1)
+QCFG: “nwscanseq”,(00-0102030405),(0,1)
+QCFG: “servicedomain”,(0,1,2),(0,1)
+QCFG: “roamservice”,(1,2,255),(0,1)
+QCFG: “band”,(0-200),(0-7FFFFFFFFFFFFFFF),(0-7FFFFFFFFFFFFFFF),(0,1)
+QCFG: “rrc”,(0-4)
+QCFG: “msc”,(0-2)
+QCFG: “sgsn”,(0-2)
+QCFG: “hsdpacat”,(6,8,10-24)
+QCFG: “hsupacat”,(5,6)
+QCFG: “pdp/duplicatechk”,(0,1)
+QCFG: “tdscsq”,(0,1)
+QCFG: “airplanecontrol”,(0,1)
+QCFG: “ledmode”,(0,1)
+QCFG: “ehrpd”,(0,7)
+QCFG: “usbid”,,
+QCFG: “usbee”,
+QCFG: “usbnet”,<0-2>
+QCFG: “usbcfg”,,,,,<at_port>,,,
+QCFG: “urc/ri/ring”,(“off”,“pulse”,“always”,“auto”,“wave”),(1-2000),(1-10000),(1-10000),(“off”,“on”),(1-5)
+QCFG: “urc/ri/smsincoming”,(“off”,“pulse”,“always”),(1-2000),(1-5)
+QCFG: “urc/ri/other”,(“off”,“pulse”),(1-2000),(1-5)
+QCFG: “risignaltype”,(“respective”,“physical”)
+QCFG: “urc/delay”,(0,1)
+QCFG: “agps/string”,(0,1)
+QCFG: “cdmaruim”,(0,1)
+QCFG: “cmux/urcport”,(0-4)
+QCFG: “ModemRstLevel”,(0,1)
+QCFG: “ApRstLevel”,(0,1)
+QCFG: “ltectcc/smsstorage”[,(0,1)]
+QCFG: “noauthcheck”,(0,1)
+QCFG: “nwscanmodeex”,(1-63)
+QCFG: “oostimer”,,,
+QCFG: “diversity”,(0-1)
+QCFG: “ppp/termframe”,(0,1)
+QCFG: “nwoptmz/acq”,(0,1),(60-16777200)
+QCFG: “ims”,(0-2)
+QCFG: “pcmclk”,(0,1)
+QCFG: “tone/incoming”,(0,1)
+QCFG: “rssi”,(0-20)
+QCFG: “cdmasms/cmtformat”[,(0,1)]
+QCFG: “ltesms/format”[,(0,1)]
+QCFG: “amrcodec”,(0-255)
+QCFG: “apready”,(0,1),(0,1),(100-3000)
+QCFG: “sleepind/level”,(0,1)
+QCFG: “wakeupin/level”,(0,1)
+QCFG: “urc/cache”,(0,1)
+QCFG: “thermal/modem”[,,,]
+QCFG: “thermal/limit_rates”[,]
+QCFG: “lte/bandprior”,(1-43),(1-43),(1-43)
+QCFG: “codec/powsave”,(0,1)
+QCFG: “qmisync”,(0,1)
+QCFG: “disrplmn”,(0,1)
+QCFG: “vts/async”,(0,1)
+QCFG: “urc/ri/pin”,(“uart_ri”,“uart_dcd”)
+QCFG: “iproute_enable”,(0,1)
+QCFG: “imsreg/iptype”,(0,1)
+QCFG: “stkauto/setupmenutr”,(0,1)
+QCFG: “eps/guti_enable”,(0,1)
+QCFG: “qcautoconnect”,(0,1)
+QCFG: “ftm/mbim”,(0,1)
+QCFG: “volte/disable”,(0,1)
+QCFG: “multi_ip_package”,,<package_max_len>,<package_max_count_in_queue>,
No, it tells you the supported format for write command(s).
If you want to read, use AT+QCFG="band". Please refer to the manual(s).
