I am working with the EC25-AF module and trying to send a test MMS text message. I have been able to successfully send using another carrier, the only difference being that one was IPV4 where as this one is “IPV4V6”.
The response I receive is always +QMMSEND: 769,0, which means “PDP deactivated”.
I am able to successfully send HTTP commands using the same configuration.
Is there some sort of log available that I can query to get a more detailed message?
I was able to quire the EC2x&EG9x&EM05_MMS_AT_Commands_Manual_V1.0 document, but I am wondering if there is an updated version or complimentary documents with additional configuration commands.
Output: ATI
Input: Quectel
Input: EC25
Input: Revision: EC25AFAR02A05M4G
Input: OK
Output: AT+QIACT=1
Input: OK
Output: AT+QIACT?
Input: +QIACT: 1,1,2,"FD04:C9D8:4F9E:BF94:2607:FB90:93CE:72D"
Input: OK
Output: AT+QMMSCFG="contextid"
Input: +QMMSCFG: "contextid",1
Input: OK
Output: AT+QMMSCFG="proxy"
Input: +QMMSCFG: "proxy","68.28.31.7",80
Input: OK
Output: AT+QMMSCFG="mmsc"
Input: +QMMSCFG: "mmsc","http://mm.myboostmobile.com"
Input: OK
Output: AT+QMMSCFG="character"
Input: +QMMSCFG: "character","UTF8"
Input: OK
Output: AT+QMMSCFG="sendparam"
Input: +QMMSCFG: "sendparam",6,3,0,0,2,4
Input: OK
Output: AT+QMMSCFG="supportfield"
Input: +QMMSCFG: "supportfield",0
Input: OK
Output: AT+QFOPEN="RAM:test.txt",1
Input: +QFOPEN: 3000
Input: OK
Output: AT+QFWRITE=3000,9,301
Input: CONNECT
Output: testing12
Input: +QFWRITE: 9,9
Input: OK
Output: AT+QFCLOSE=3000
Input: OK
Output: AT+QMMSEDIT=0
Input: OK
Output: AT+QMMSEDIT=1,1,"0000000000"
Input: OK
Output: AT+QMMSEDIT=5,1,"RAM:test.txt"
Input: OK
Output: AT+QMMSEND=100
Input: OK
Input: +QMMSEND: 769,0
