Hello, I am an owner of the Quectel RM502Q_AE
This is my firmware revision:
AT+QGMR
RM502QAEAAR13A04M4G_01.203.01.203
When I try to ask for ADB key:
AT+QADBKEY?
+QADBKEY: 96037932
Then the challenge should be solvable with:
AT+QADBKEY=“ONDfp61mt7sPpc4”
But instead, this is the result:
Prima abilitare…
Hi folks,
I have a RG520N, firmware RG520NEUDBR01A04M8GA, and I am trying to enable ADB, but I cannot detect it from ADb tool
I understand should be the sixth bit in
+QCFG: “usbcfg”,0x2C7C,0x0801,1,1,1,1,1,0,0
is this correct ?
Do I need a key for unlocking ADB? Running AT+QADBKEY? returns an error.
Thanks in advance
vedi codice pid, vid
vendor che differisce.
Poi sblocca.
@Emre_Karabek I managed to get AT+QCFG=“usbcfg” to work, but I am unable to set to 1 the ADB bit
Also, I can’t pass the AT+QADBKEY challenge, as I described in my first post.
Check if in the release notes: “AT+QADBKEY was no longer supported.” by the latest fw…
Ok, so ask directly to @Niki.Liu-Q wath is the matter.
@silvia loop silvia to suppot this issue, thanks~
silvia
August 27, 2025, 8:18am
9
Dear @Alessandro
Do you configure USB port to PCIE?
It seems your device can’t enable ADB.
No. The modem has been reset to factory settings to work in usb mode. The only thing that has been asked after AT+QCFG=“ResetFactory” is the command to unlock it. AT+QADBKEY?
