Cannot connect M66 to IBM bluemix server using MQTT AT commands
Hi, I am getting some error while trying to connect to my IBM server using M66 module with AT commands. I am pasting the log below.
AT
AT+QMTOPEN=0,“.messaging.internetofthings.ibmcloud.com”,1883
+QMTOPEN: 0,0
AT+QMTCONN=?
+QMTCONN: (0-5),“”[,“”[,“”]]
AT+QMTCONN=0,“MY IBM CLIENT ID”[,“MY IBM USERNAME”[,“MY IBM PASSWORD”]]
+CME ERROR: 3518
I confirmed that server runs at the moment and other devices (WiFi) were connected successfully. Please let me know what went wrong
Could you please check the clientID, username, password in the following command?
User name and password are optional and you don’t need to use “[” character in the command.
Please see the following example MQTT application.
Please refer to the attached MQTT application document to get more detailed information about the commands. Quectel_GSM_MQTT_Application_Note_V1.2.pdf (518.0 KB)
ATI
Quectel_Ltd
Quectel_M66
Revision: M66FAR02A06BT
AT+CPIN?
+CPIN: READY
AT+CREG?
+CREG: 0,1
AT+CGREG?
+CGREG: 0,1
AT+QIFGCNT=0
AT+QIDNSIP=0
AT+QICSGP=1,“internet”
AT+QIREGAPP
AT+QIACT
AT+QILOCIP
10.85.38.164
AT+QMTOPEN=1,“test.mosquitto.org”,1883
+QMTOPEN: 1,0
AT+QMTOPEN?
+QMTOPEN: 1,“test.mosquitto.org”,1883
AT+QMTCONN=1,“clientID123”
+QMTCONN: 1,0,0
AT+QMTSUB=1,1,“topic/test1”,2
+QMTSUB: 1,1,0,2
+QMTRECV: 1,0,topic/test1,test1
+QMTRECV: 1,0,topic/test1,message to topic/test1
AT+QMTPUB=1,1,2,1,“topic/test1”
module sent messafe  ge
+QMTRECV: 1,1,topic/test1,module sent messag
+QMTPUB: 1,1,0
module sent message to topic/test1
+QMTRECV: 1,2,topic/test1,module sent message to topic/test1
+QMTPUB: 1,1,0
+QMTPUB: 1,1,0
Hi, Thank you for your reply.Here I lists what I have done after,
  • Followed your example code,
AT
ATI
Quectel_Ltd
Quectel_M66
Revision: M66FAR02A04BT
AT+CPIN?
+CPIN: READY
AT+CREG?
+CREG: 0,1
AT+CGREG?
+CGREG: 0,1
AT+QIFGCNT=0
AT+QIDNSIP=0
AT+QIREGAPP
AT+QIACT
AT+QILOCIP
10.66.98.29
AT+QMTOPEN=1,“<MY_BMIX_ORG_ID>.messaging.internetofthings.ibmcloud.com”,1883
+QMTOPEN: 1,0
AT+QMTCONN=1,“a:5xxxxxxxxxxxxxxd80” // edited
+QMTSTAT: 1,3
+QMTCONN: 1,2
  • Also tried the format AT+QMTCONN=1,“CLIENT_ID”[,“BMIX_USER”[,“BMIX_KEY”]]
    This time, results => +CME ERROR: 3518
  • Another format tried => AT+QMTCONN=0,“CLIENT_ID”,“BMIX_USER”,“BMIX_KEY”
    Result is =>
    +QMTSTAT: 0,3
    +QMTCONN: 0,2
I have double checked the Client ID,User and key ,but couldnt find any difference.Also these credentials have been used by us for a couple of years successfully.I found the only difference between the example code provided and mine was the firmware version.
In example code above its Revision: M66FAR02A06BT and in my case its Revision: M66FAR02A04BT.
I am really stuck with this activity and expects your valuable reply.
Hi
As per our mail communication your issue resolved, It was issue with your SIM card.
Regards
Rahul
Ya, It was a problem related to the SIM card I used. Thank u very much for your supprt.
Hi @rahul.mahakalkar
I have a similar issue, however my CME 3518 error occurs when the AT+QMTSUB command is run. Please see below commands log and where the error occurs. Your assistance will be much appreciated.
AT+CGREG?
+CGREG: 1,1
Return value from AT COMMAND return: 0
AT+QIFGCNT=0
AutoFlush
AutoFlush
AT+QIREGAPP
AutoFlush
SYSTEM:Housekeeping
AT+QIACT
AT+QMTCFG=“SHOWRECVLEN”,1,1
SYSTEM:Housekeeping
AT+QMTCFG=“VERSION”,1,1
AutoFlush
AT+QMTOPEN=0,“[my mqtt server]”,1883
//<Open a MQTT client successfully
AutoFlush
AT+QMTCONN=0,“WernesExample”
//<Connect to MQTT server successfully
AutoFlush
AT+QMTSUB=0,1,“topic/example”,0
+CME ERROR: 3518
Return value from AT COMMAND return: -1
AT+QMTSUB=0,1,“Protecto”,0
+CME ERROR: 3518
