When I put the rm520 into pcie data mode the NMEA stream on ttyUSB1 stops.
How can I get it back?
Thanks.
Thanks.
Dear @steely-glint
Could you send AT commands now? Please confirm if you can detect device.
Hello, yes, I can see the device - and I’ve mod loaded a serial driver
khadas@k4:/dev$ ls /dev/ttyUSB*
/dev/ttyUSB0 /dev/ttyUSB1 /dev/ttyUSB2 /dev/ttyUSB3
The network is up.
khadas@k4:/dev$ ifconfig rmnet_mhi0.1
rmnet_mhi0.1: flags=193<UP,RUNNING,NOARP> mtu 1472
inet 192.0.0.2 netmask 255.255.255.224
inet6 2a01:599:10c:9542:b4ac:a1c:7d83:435a prefixlen 64 scopeid 0x0<global>
inet6 2a01:599:10c:9542:50:f4ff:fe00:0 prefixlen 64 scopeid 0x0<global>
ether 02:50:f4:00:00:00 txqueuelen 1000 (Ethernet)
RX packets 30 bytes 3497 (3.4 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 56 bytes 6531 (6.5 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
And I can send AT commands
khadas@k4:/dev$ sudo minicom -D /dev/ttyUSB2
Welcome to minicom 2.8
OPTIONS: I18n
Port /dev/ttyUSB2, 09:42:29
Press CTRL-A Z for help on special keys
AT+QGPS=1
+CME ERROR: 504
and get GPS LOC on demand.
AT+QGPSLOC=0
+QGPSLOC: 105653.00,XXXX.0728N,XXXX.6277E,2.5,38.4,3,,0.0,0.0,070923,08
But no stream on /dev/ttyUSB1
OPTIONS: I18n
Port /dev/ttyUSB1, 10:56:25
If I switch to USB data mode I get the stream NMEA on ttyUSB1
Is there somewhere else I can read the NMEA stream ?
Thanks.
Tim.
@silvia Hi, any progress on this question?
To re-state it:
If I set pcie mode for my high speed data link using
AT+QCFG=“data_interface”,1
and quectel-CM
I stop getting the GNSS NEMA data stream on /dev/ttyUSB1
(ttyUSB2 still accepts AT commands)
Can you help ?
Thanks.
Dear @steely-glint
Did you check the output port via AT+QGPSCFG=“outport”?
Dear @steely-glint
Could you check if your device show any /dev/mhi*?
@silvia Here’s the output you requested:
AT+QGPSCFG="outport"
+QGPSCFG: "outport",usbnmea
and
khadas@k4:~$ ls -l /dev/mhi*
crw------- 1 root root 506, 0 Sep 20 14:43 /dev/mhi_BHI
crw------- 1 root root 507, 1 Sep 20 14:43 /dev/mhi_DIAG
crw------- 1 root root 507, 3 Sep 20 14:43 /dev/mhi_DUN
crw------- 1 root root 507, 0 Sep 20 14:43 /dev/mhi_LOOPBACK
crw------- 1 root root 507, 2 Sep 20 14:43 /dev/mhi_QMI0
khadas@k4:~$
Thanks for the quick reply.
Tim.
Dear @steely-glint
As checked internally, when use PCIE mode, nmea will output from /dev/mhi_LOOPBACK, please use this and test again.
Yes, that works !
Thank you for quick help.
Tim.
