Can someone help me to convert this AT+QGNSSRD? data output to Long and Lat
I Am Using MC25 Module and it’s working good
Here I have given the log :slight_smile:
2022-08-24 16:17:02:177_S:] AT+CPIN?
[2022-08-24 16:17:09:281_R:]
[2022-08-24 16:17:13:489_R:] RDY
[2022-08-24 16:17:13:489_R:] +CFUN: 1
[2022-08-24 16:17:16:725_R:] +CPIN: READY
[2022-08-24 16:17:18:142_S:] AT+QGNSSRD?
[2022-08-24 16:17:18:265_R:] Call Ready
[2022-08-24 16:17:18:265_R:] +CME ERROR: Operation failed
[2022-08-24 16:17:19:521_R:] SMS Ready
[2022-08-24 16:17:22:016_R:] RDY
[2022-08-24 16:17:22:016_R:] +CFUN: 1
[2022-08-24 16:17:25:259_R:] +CPIN: READY
[2022-08-24 16:17:26:792_R:] Call Ready
[2022-08-24 16:17:26:797_S:] AT+QGNSSC=1
[2022-08-24 16:17:27:438_R:] OK
[2022-08-24 16:17:28:048_R:] SMS Ready
[2022-08-24 16:17:31:218_S:] AT+QGNSSRD?
[2022-08-24 16:17:31:328_R:] +QGNSSRD: $GNRMC,104725.000,V,240822,N,V22
[2022-08-24 16:17:31:390_R:] $GNVTG,N
2E
[2022-08-24 16:17:31:390_R:] $GNGGA,104725.000,0,00,25.5,7F
[2022-08-24 16:17:31:453_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 16:17:31:516_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 16:17:31:516_R:] $GPGSV,1,1,00,0
65
[2022-08-24 16:17:31:579_R:] $BDGSV,1,1,00,074
[2022-08-24 16:17:31:579_R:] $GNGLL,104725.000,V,N
61
[2022-08-24 16:17:31:642_R:] OK
[2022-08-24 16:17:41:712_S:] AT+QGNSSRD?
[2022-08-24 16:17:41:838_R:] +QGNSSRD: $GNRMC,104736.000,V,240822,N,V20
[2022-08-24 16:17:41:900_R:] $GNVTG,N
2E
[2022-08-24 16:17:41:900_R:] $GNGGA,104736.000,0,00,25.5,7D
[2022-08-24 16:17:41:963_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 16:17:42:026_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 16:17:42:026_R:] $GPGSV,1,1,00,0
65
[2022-08-24 16:17:42:089_R:] $BDGSV,1,1,00,074
[2022-08-24 16:17:42:089_R:] $GNGLL,104736.000,V,N
63
[2022-08-24 16:17:42:152_R:] OK
/* Start AT SYNC: Send AT every 500ms, if receive OK, SYNC success, if no OK return after sending AT 10 times, SYNC fail */
[2022-08-24 16:44:01:234_S:] AT
[2022-08-24 16:44:01:381_R:] OK
[2022-08-24 16:44:01:397_S:] ATI
[2022-08-24 16:44:01:570_R:] Quectel_Ltd
[2022-08-24 16:44:01:570_R:] Quectel_MC25
[2022-08-24 16:44:01:570_R:] Revision: MC25MBR01A02
[2022-08-24 16:44:01:632_R:] OK
[2022-08-24 16:44:01:648_S:] ATI
[2022-08-24 16:44:01:821_R:] Quectel_Ltd
[2022-08-24 16:44:01:821_R:] Quectel_MC25
[2022-08-24 16:44:01:821_R:] Revision: MC25MBR01A02
[2022-08-24 16:44:01:884_R:] OK
/* Use ATV1 to set the response format */
[2022-08-24 16:44:01:899_S:] ATV1
[2022-08-24 16:44:02:072_R:] OK
[2022-08-24 16:44:02:261_R:] +CPIN: READY
/* Use ATE1 to enable echo mode */
[2022-08-24 16:44:02:323_S:] ATE1
[2022-08-24 16:44:02:433_R:] OK
/* Use AT+CMEE=2 to enable result code and use verbose values */
[2022-08-24 16:44:02:654_S:] AT+CMEE=2
[2022-08-24 16:44:02:764_R:] AT+CMEE=2
[2022-08-24 16:44:02:764_R:] OK
/* Get the baudrate, if the value is 0 (auto baudrate), then it will be set to 115200 (fixed baudrate) to assure reliable communication and avoid any problems caused by undetermined baudrate between DCE and DTE, value of IPR should be saved with AT&W */
[2022-08-24 16:44:03:079_S:] AT+IPR?
[2022-08-24 16:44:03:189_R:] AT+IPR?
[2022-08-24 16:44:03:189_R:] +IPR: 9600
[2022-08-24 16:44:03:189_R:] OK
/* Use ATI to get module information of Manufacturer ID, Device module and Firmware version */
[2022-08-24 16:44:03:299_S:] ATI
[2022-08-24 16:44:03:409_R:] ATI
[2022-08-24 16:44:03:409_R:] Quectel_Ltd
[2022-08-24 16:44:03:409_R:] Quectel_MC25
[2022-08-24 16:44:03:409_R:] Revision: MC25MBR01A02
[2022-08-24 16:44:03:472_R:] OK
/* Use AT+GSN to query the IMEI of module */
[2022-08-24 16:44:03:582_S:] AT+GSN
[2022-08-24 16:44:03:692_R:] AT+GSN
[2022-08-24 16:44:03:692_R:] 863221042483816
[2022-08-24 16:44:03:692_R:] OK
[2022-08-24 16:44:03:755_R:] Call Ready
/* Use AT+CPIN? to query the SIM card status : SIM card inserted or not, locked or unlocked */
[2022-08-24 16:44:04:195_S:] AT+CPIN?
[2022-08-24 16:44:04:305_R:] AT+CPIN?
[2022-08-24 16:44:04:305_R:] +CPIN: READY
[2022-08-24 16:44:04:305_R:] OK
/* Use AT+CIMI to query the IMSI of SIM card */
[2022-08-24 16:44:04:431_S:] AT+CIMI
[2022-08-24 16:44:04:541_R:] AT+CIMI
[2022-08-24 16:44:04:541_R:] 404400979555237
[2022-08-24 16:44:04:541_R:] OK
/* Use AT+QCCID to query ICCID number of SIM card */
[2022-08-24 16:44:04:761_S:] AT+QCCID
[2022-08-24 16:44:04:870_R:] AT+QCCID
[2022-08-24 16:44:04:870_R:] 8991000904745028402F
[2022-08-24 16:44:04:870_R:] OK
/* Use AT+CSQ to query current signal quality */
[2022-08-24 16:44:04:980_S:] AT+CSQ
[2022-08-24 16:44:05:090_R:] AT+CSQ
[2022-08-24 16:44:05:090_R:] +CSQ: 3,0
[2022-08-24 16:44:05:090_R:] OK
/* Use AT+CREG? /AT+CGREG? to query the network registration status. */
[2022-08-24 16:44:05:090_S:] AT+CREG?
[2022-08-24 16:44:05:279_R:] AT+CREG?
[2022-08-24 16:44:05:279_R:] +CREG: 0,0
[2022-08-24 16:44:05:279_R:] OK
[2022-08-24 16:44:05:295_S:] AT+CGREG?
[2022-08-24 16:44:05:468_R:] AT+CGREG?
[2022-08-24 16:44:05:468_R:] +CGREG: 0,0
[2022-08-24 16:44:05:468_R:] OK
[2022-08-24 16:44:07:479_S:] AT+CREG?
[2022-08-24 16:44:07:589_R:] AT+CREG?
[2022-08-24 16:44:07:589_R:] +CREG: 0,0
[2022-08-24 16:44:07:589_R:] OK
[2022-08-24 16:44:07:604_S:] AT+CGREG?
[2022-08-24 16:44:07:776_R:] AT+CGREG?
[2022-08-24 16:44:07:776_R:] +CGREG: 0,0
[2022-08-24 16:44:07:776_R:] OK
[2022-08-24 16:44:09:788_S:] AT+CREG?
[2022-08-24 16:44:09:898_R:] AT+CREG?
[2022-08-24 16:44:09:898_R:] +CREG: 0,0
[2022-08-24 16:44:09:898_R:] OK
[2022-08-24 16:44:09:914_S:] AT+CGREG?
[2022-08-24 16:44:10:086_R:] AT+CGREG?
[2022-08-24 16:44:10:086_R:] +CGREG: 0,0
[2022-08-24 16:44:10:086_R:] OK
[2022-08-24 16:44:12:099_S:] AT+CREG?
[2022-08-24 16:44:12:209_R:] AT+CREG?
[2022-08-24 16:44:12:209_R:] +CREG: 0,0
[2022-08-24 16:44:12:209_R:] OK
[2022-08-24 16:44:12:224_S:] AT+CGREG?
[2022-08-24 16:44:12:397_R:] AT+CGREG?
[2022-08-24 16:44:12:397_R:] +CGREG: 0,0
[2022-08-24 16:44:12:397_R:] OK
[2022-08-24 16:44:14:409_S:] AT+CREG?
[2022-08-24 16:44:14:518_R:] AT+CREG?
[2022-08-24 16:44:14:518_R:] +CREG: 0,0
[2022-08-24 16:44:14:518_R:] OK
[2022-08-24 16:44:14:534_S:] AT+CGREG?
[2022-08-24 16:44:14:581_S:] AT+QGNSSRD?
[2022-08-24 16:44:14:754_R:] AT+QGNSSRD?
[2022-08-24 16:44:14:754_R:] +CME ERROR: Operation failed
[2022-08-24 16:44:16:830_S:] AT+CREG?
[2022-08-24 16:44:16:940_R:] AT+CREG?
[2022-08-24 16:44:16:940_R:] +CREG: 0,0
[2022-08-24 16:44:16:940_R:] OK
[2022-08-24 16:44:16:956_S:] AT+CGREG?
[2022-08-24 16:44:17:129_R:] AT+CGREG?
[2022-08-24 16:44:17:129_R:] +CGREG: 0,0
[2022-08-24 16:44:17:129_R:] OK
[2022-08-24 16:44:19:141_S:] AT+CREG?
[2022-08-24 16:44:19:251_R:] AT+CREG?
[2022-08-24 16:44:19:251_R:] +CREG: 0,0
[2022-08-24 16:44:19:251_R:] OK
[2022-08-24 16:44:19:267_S:] AT+CGREG?
[2022-08-24 16:44:19:424_R:] AT+CGREG?
[2022-08-24 16:44:19:424_R:] +CGREG: 0,0
[2022-08-24 16:44:19:424_R:] OK
[2022-08-24 16:44:21:435_S:] AT+CREG?
[2022-08-24 16:44:21:545_R:] AT+CREG?
[2022-08-24 16:44:21:545_R:] +CREG: 0,0
[2022-08-24 16:44:21:545_R:] OK
[2022-08-24 16:44:21:560_S:] AT+CGREG?
[2022-08-24 16:44:21:733_R:] AT+CGREG?
[2022-08-24 16:44:21:733_R:] +CGREG: 0,0
[2022-08-24 16:44:21:733_R:] OK
[2022-08-24 16:44:23:746_S:] AT+CREG?
[2022-08-24 16:44:23:856_R:] AT+CREG?
[2022-08-24 16:44:23:856_R:] +CREG: 0,0
[2022-08-24 16:44:23:856_R:] OK
[2022-08-24 16:44:23:872_S:] AT+CGREG?
[2022-08-24 16:44:24:044_R:] AT+CGREG?
[2022-08-24 16:44:24:044_R:] +CGREG: 0,0
[2022-08-24 16:44:24:044_R:] OK
[2022-08-24 16:44:26:056_S:] AT+CREG?
[2022-08-24 16:44:26:166_R:] AT+CREG?
[2022-08-24 16:44:26:166_R:] +CREG: 0,0
[2022-08-24 16:44:26:166_R:] OK
[2022-08-24 16:44:26:182_S:] AT+CGREG?
[2022-08-24 16:44:26:229_S:] AT+QGNSSC=1
[2022-08-24 16:44:26:762_R:] OK
[2022-08-24 16:44:26:762_R:] AT+QGNSSC=1
[2022-08-24 16:44:26:762_R:] +CME ERROR: Operation failed
/* Make sure the Antenna is connected and the network is normal /
[2022-08-24 16:44:34:246_S:] AT+QGNSSC=1
[2022-08-24 16:44:34:371_R:] AT+QGNSSC=1
[2022-08-24 16:44:34:371_R:] +CME ERROR: Operation failed
[2022-08-24 16:44:36:778_S:] AT+QGNSSC=0
[2022-08-24 16:44:36:888_R:] AT+QGNSSC=0
[2022-08-24 16:44:36:888_R:] OK
[2022-08-24 16:44:39:968_S:] AT+QGNSSC=1
[2022-08-24 16:44:40:093_R:] AT+QGNSSC=1
[2022-08-24 16:44:40:517_R:] OK
[2022-08-24 16:44:51:279_S:] AT+QGNSSRD=“NMEA/RMC”
[2022-08-24 16:44:51:405_R:] AT+QGNSSRD=“NMEA/RMC”
[2022-08-24 16:44:51:405_R:] +QGNSSRD: $GNRMC,V,N,V
37
[2022-08-24 16:44:51:468_R:] OK
[2022-08-24 16:45:01:555_S:] AT+QGNSSRD?
[2022-08-24 16:45:01:665_R:] AT+QGNSSRD?
[2022-08-24 16:45:01:665_R:] +QGNSSRD: $GNRMC,V,N,V37
[2022-08-24 16:45:01:729_R:] $GNVTG,N
2E
[2022-08-24 16:45:01:729_R:] $GNGGA,0,00,25.5,64
[2022-08-24 16:45:01:792_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 16:45:01:792_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 16:45:01:854_R:] $GPGSV,1,1,00,0
65
[2022-08-24 16:45:01:917_R:] $BDGSV,1,1,00,074
[2022-08-24 16:45:01:917_R:] $GNGLL,V,N
7A
[2022-08-24 16:45:01:917_R:] OK
[2022-08-24 16:58:53:246_R:] RDY
[2022-08-24 16:58:53:246_R:] +CFUN: 1
[2022-08-24 16:58:56:483_R:] +CPIN: READY
[2022-08-24 16:58:58:072_R:] Call Ready
[2022-08-24 16:58:59:361_R:] SMS Ready
[2022-08-24 17:03:16:405_S:] AT+QGNSSRD?
[2022-08-24 17:10:01:665_S:] AT+QGNSSRD?
[2022-08-24 17:10:43:146_S:] AT
[2022-08-24 17:10:43:304_R:] OK
[2022-08-24 17:10:43:319_S:] ATI
[2022-08-24 17:10:43:492_R:] Quectel_Ltd
[2022-08-24 17:10:43:492_R:] Quectel_MC25
[2022-08-24 17:10:43:492_R:] Revision: MC25MBR01A02
[2022-08-24 17:10:43:554_R:] OK
[2022-08-24 17:10:43:570_S:] ATI
[2022-08-24 17:10:43:743_R:] Quectel_Ltd
[2022-08-24 17:10:43:743_R:] Quectel_MC25
[2022-08-24 17:10:43:743_R:] Revision: MC25MBR01A02
[2022-08-24 17:10:43:806_R:] OK
[2022-08-24 17:10:43:821_S:] ATV1
[2022-08-24 17:10:43:995_R:] OK
[2022-08-24 17:10:44:246_S:] ATE1
[2022-08-24 17:10:44:356_R:] OK
[2022-08-24 17:10:44:576_S:] AT+CMEE=2
[2022-08-24 17:10:44:686_R:] AT+CMEE=2
[2022-08-24 17:10:44:686_R:] OK
[2022-08-24 17:10:45:000_S:] AT+IPR?
[2022-08-24 17:10:45:110_R:] AT+IPR?
[2022-08-24 17:10:45:110_R:] +IPR: 9600
[2022-08-24 17:10:45:110_R:] OK
[2022-08-24 17:10:45:220_S:] ATI
[2022-08-24 17:10:45:329_R:] ATI
[2022-08-24 17:10:45:329_R:] Quectel_Ltd
[2022-08-24 17:10:45:329_R:] Quectel_MC25
[2022-08-24 17:10:45:329_R:] Revision: MC25MBR01A02
[2022-08-24 17:10:45:392_R:] OK
[2022-08-24 17:10:45:502_S:] AT+GSN
[2022-08-24 17:10:45:612_R:] AT+GSN
[2022-08-24 17:10:45:612_R:] 863221042483816
[2022-08-24 17:10:45:612_R:] OK
[2022-08-24 17:10:46:115_S:] AT+CPIN?
[2022-08-24 17:10:46:225_R:] AT+CPIN?
[2022-08-24 17:10:46:225_R:] +CPIN: READY
[2022-08-24 17:10:46:225_R:] OK
[2022-08-24 17:10:46:350_S:] AT+CIMI
[2022-08-24 17:10:46:460_R:] AT+CIMI
[2022-08-24 17:10:46:460_R:] 404400979555237
[2022-08-24 17:10:46:460_R:] OK
[2022-08-24 17:10:46:680_S:] AT+QCCID
[2022-08-24 17:10:46:790_R:] AT+QCCID
[2022-08-24 17:10:46:790_R:] 8991000904745028402F
[2022-08-24 17:10:46:790_R:] OK
[2022-08-24 17:10:46:901_S:] AT+CSQ
[2022-08-24 17:10:47:010_R:] AT+CSQ
[2022-08-24 17:10:47:010_R:] +CSQ: 11,0
[2022-08-24 17:10:47:010_R:] OK
[2022-08-24 17:10:47:010_S:] AT+CREG?
[2022-08-24 17:10:47:199_R:] AT+CREG?
[2022-08-24 17:10:47:199_R:] +CREG: 0,0
[2022-08-24 17:10:47:199_R:] OK
[2022-08-24 17:10:47:215_S:] AT+CGREG?
[2022-08-24 17:10:47:387_R:] AT+CGREG?
[2022-08-24 17:10:47:387_R:] +CGREG: 0,0
[2022-08-24 17:10:47:387_R:] OK
[2022-08-24 17:10:49:399_S:] AT+CREG?
[2022-08-24 17:10:49:509_R:] AT+CREG?
[2022-08-24 17:10:49:509_R:] +CREG: 0,0
[2022-08-24 17:10:49:509_R:] OK
[2022-08-24 17:10:49:524_S:] AT+CGREG?
[2022-08-24 17:10:49:697_R:] AT+CGREG?
[2022-08-24 17:10:49:697_R:] +CGREG: 0,0
[2022-08-24 17:10:49:697_R:] OK
[2022-08-24 17:10:51:710_S:] AT+CREG?
[2022-08-24 17:10:51:820_R:] AT+CREG?
[2022-08-24 17:10:51:820_R:] +CREG: 0,0
[2022-08-24 17:10:51:820_R:] OK
[2022-08-24 17:10:51:835_S:] AT+CGREG?
[2022-08-24 17:10:52:008_R:] AT+CGREG?
[2022-08-24 17:10:52:008_R:] +CGREG: 0,0
[2022-08-24 17:10:52:008_R:] OK
[2022-08-24 17:10:54:020_S:] AT+CREG?
[2022-08-24 17:10:54:130_R:] AT+CREG?
[2022-08-24 17:10:54:130_R:] +CREG: 0,0
[2022-08-24 17:10:54:130_R:] OK
[2022-08-24 17:10:54:145_S:] AT+CGREG?
[2022-08-24 17:10:54:318_R:] AT+CGREG?
[2022-08-24 17:10:54:318_R:] +CGREG: 0,0
[2022-08-24 17:10:54:318_R:] OK
[2022-08-24 17:10:56:330_S:] AT+CREG?
[2022-08-24 17:10:56:440_R:] AT+CREG?
[2022-08-24 17:10:56:440_R:] +CREG: 0,0
[2022-08-24 17:10:56:440_R:] OK
[2022-08-24 17:10:56:455_S:] AT+CGREG?
[2022-08-24 17:10:56:628_R:] AT+CGREG?
[2022-08-24 17:10:56:628_R:] +CGREG: 0,0
[2022-08-24 17:10:56:628_R:] OK
[2022-08-24 17:10:58:638_S:] AT+CREG?
[2022-08-24 17:10:58:748_R:] AT+CREG?
[2022-08-24 17:10:58:748_R:] +CREG: 0,0
[2022-08-24 17:10:58:748_R:] OK
[2022-08-24 17:10:58:764_S:] AT+CGREG?
[2022-08-24 17:10:58:937_R:] AT+CGREG?
[2022-08-24 17:10:58:937_R:] +CGREG: 0,0
[2022-08-24 17:10:58:937_R:] OK
[2022-08-24 17:11:00:949_S:] AT+CREG?
[2022-08-24 17:11:01:059_R:] AT+CREG?
[2022-08-24 17:11:01:059_R:] +CREG: 0,0
[2022-08-24 17:11:01:059_R:] OK
[2022-08-24 17:11:01:075_S:] AT+CGREG?
[2022-08-24 17:11:01:248_R:] AT+CGREG?
[2022-08-24 17:11:01:248_R:] +CGREG: 0,0
[2022-08-24 17:11:01:248_R:] OK
[2022-08-24 17:11:01:955_S:] AT+QGNSSC=1
[2022-08-24 17:11:02:064_R:] AT+QGNSSC=1
[2022-08-24 17:11:02:504_R:] OK
[2022-08-24 17:11:03:259_S:] AT+CREG?
[2022-08-24 17:11:03:369_R:] AT+CREG?
[2022-08-24 17:11:03:369_R:] +CREG: 0,0
[2022-08-24 17:11:03:369_R:] OK
[2022-08-24 17:11:03:384_S:] AT+CGREG?
[2022-08-24 17:11:03:557_R:] AT+CGREG?
[2022-08-24 17:11:03:557_R:] +CGREG: 0,0
[2022-08-24 17:11:03:557_R:] OK
[2022-08-24 17:11:05:568_S:] AT+CREG?
[2022-08-24 17:11:05:678_R:] AT+CREG?
[2022-08-24 17:11:05:678_R:] +CREG: 0,0
[2022-08-24 17:11:05:678_R:] OK
[2022-08-24 17:11:05:694_S:] AT+CGREG?
[2022-08-24 17:11:05:867_R:] AT+CGREG?
[2022-08-24 17:11:05:867_R:] +CGREG: 0,0
[2022-08-24 17:11:05:867_R:] OK
[2022-08-24 17:11:07:879_S:] AT+CREG?
[2022-08-24 17:11:07:989_R:] AT+CREG?
[2022-08-24 17:11:07:989_R:] +CREG: 0,0
[2022-08-24 17:11:07:989_R:] OK
[2022-08-24 17:11:08:005_S:] AT+CGREG?
[2022-08-24 17:11:08:178_R:] AT+CGREG?
[2022-08-24 17:11:08:178_R:] +CGREG: 0,0
[2022-08-24 17:11:08:178_R:] OK
[2022-08-24 17:11:27:223_S:] AT+QGNSSRD?
[2022-08-24 17:11:27:333_R:] AT+QGNSSRD?
[2022-08-24 17:11:27:333_R:] +QGNSSRD: $GNRMC,V,N,V
37
[2022-08-24 17:11:27:395_R:] $GNVTG,N2E
[2022-08-24 17:11:27:395_R:] $GNGGA,0,00,25.5,64
[2022-08-24 17:11:27:459_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:11:27:459_R:] $GNGSA,A,1,25.5,25.5,25.5,4
04
[2022-08-24 17:11:27:521_R:] $GPGSV,1,1,00,065
[2022-08-24 17:11:27:521_R:] $BDGSV,1,1,00,0
74
[2022-08-24 17:11:27:584_R:] $GNGLL,V,N*7A
[2022-08-24 17:11:27:584_R:] OK
[2022-08-24 17:14:39:363_S:] AT+QGNSSRD?
[2022-08-24 17:14:39:473_R:] AT+QGNSSRD?
[2022-08-24 17:14:39:473_R:] +QGNSSRD: $GNRMC,V,N,V37
[2022-08-24 17:14:39:536_R:] $GNVTG,N
2E
[2022-08-24 17:14:39:536_R:] $GNGGA,0,00,25.5,64
[2022-08-24 17:14:39:599_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:14:39:599_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:14:39:662_R:] $GPGSV,1,1,00,0
65
[2022-08-24 17:14:39:662_R:] $BDGSV,1,1,00,074
[2022-08-24 17:14:39:724_R:] $GNGLL,V,N
7A
[2022-08-24 17:14:39:724_R:] OK
[2022-08-24 17:22:23:018_R:] RDY
[2022-08-24 17:22:23:018_R:] +CFUN: 1
[2022-08-24 17:22:26:252_R:] +CPIN: READY
[2022-08-24 17:22:27:785_R:] Call Ready
[2022-08-24 17:22:29:044_R:] SMS Ready
[2022-08-24 17:29:36:034_S:] AT+QGNSSC=1
[2022-08-24 17:29:45:321_S:] AT
[2022-08-24 17:29:45:467_R:] OK
[2022-08-24 17:29:45:483_S:] ATI
[2022-08-24 17:29:45:656_R:] Quectel_Ltd
[2022-08-24 17:29:45:656_R:] Quectel_MC25
[2022-08-24 17:29:45:656_R:] Revision: MC25MBR01A02
[2022-08-24 17:29:45:656_R:] OK
[2022-08-24 17:29:45:735_S:] ATI
[2022-08-24 17:29:45:911_R:] Quectel_Ltd
[2022-08-24 17:29:45:911_R:] Quectel_MC25
[2022-08-24 17:29:45:911_R:] Revision: MC25MBR01A02
[2022-08-24 17:29:45:911_R:] OK
[2022-08-24 17:29:45:992_S:] ATV1
[2022-08-24 17:29:46:167_R:] OK
[2022-08-24 17:29:46:418_S:] ATE1
[2022-08-24 17:29:46:528_R:] OK
[2022-08-24 17:29:46:749_S:] AT+CMEE=2
[2022-08-24 17:29:46:859_R:] AT+CMEE=2
[2022-08-24 17:29:46:859_R:] OK
[2022-08-24 17:29:47:172_S:] AT+IPR?
[2022-08-24 17:29:47:284_R:] AT+IPR?
[2022-08-24 17:29:47:284_R:] +IPR: 9600
[2022-08-24 17:29:47:284_R:] OK
[2022-08-24 17:29:47:389_S:] ATI
[2022-08-24 17:29:47:499_R:] ATI
[2022-08-24 17:29:47:499_R:] Quectel_Ltd
[2022-08-24 17:29:47:499_R:] Quectel_MC25
[2022-08-24 17:29:47:499_R:] Revision: MC25MBR01A02
[2022-08-24 17:29:47:562_R:] OK
[2022-08-24 17:29:47:673_S:] AT+GSN
[2022-08-24 17:29:47:783_R:] AT+GSN
[2022-08-24 17:29:47:783_R:] 863221042483816
[2022-08-24 17:29:47:783_R:] OK
[2022-08-24 17:29:48:299_S:] AT+CPIN?
[2022-08-24 17:29:48:421_R:] AT+CPIN?
[2022-08-24 17:29:48:421_R:] +CPIN: READY
[2022-08-24 17:29:48:421_R:] OK
[2022-08-24 17:29:48:547_S:] AT+CIMI
[2022-08-24 17:29:48:659_R:] AT+CIMI
[2022-08-24 17:29:48:659_R:] 404400979555237
[2022-08-24 17:29:48:659_R:] OK
[2022-08-24 17:29:48:885_S:] AT+QCCID
[2022-08-24 17:29:49:004_R:] AT+QCCID
[2022-08-24 17:29:49:004_R:] 8991000904745028402F
[2022-08-24 17:29:49:004_R:] OK
[2022-08-24 17:29:49:114_S:] AT+CSQ
[2022-08-24 17:29:49:224_R:] AT+CSQ
[2022-08-24 17:29:49:224_R:] +CSQ: 17,0
[2022-08-24 17:29:49:224_R:] OK
[2022-08-24 17:29:49:224_S:] AT+CREG?
[2022-08-24 17:29:49:415_R:] AT+CREG?
[2022-08-24 17:29:49:415_R:] +CREG: 0,1
[2022-08-24 17:29:49:415_R:] OK
[2022-08-24 17:29:49:430_S:] AT+CGREG?
[2022-08-24 17:29:49:604_R:] AT+CGREG?
[2022-08-24 17:29:49:604_R:] +CGREG: 0,1
[2022-08-24 17:29:49:604_R:] OK
/* Use AT+COPS? to query current Network Operator */
[2022-08-24 17:29:49:606_S:] AT+COPS?
[2022-08-24 17:29:49:783_R:] AT+COPS?
[2022-08-24 17:29:49:909_R:] +COPS: 0,0,“airtel”
[2022-08-24 17:29:49:909_R:] OK
[2022-08-24 17:29:51:245_S:] AT+QGNSSC=1
[2022-08-24 17:29:51:372_R:] AT+QGNSSC=1
[2022-08-24 17:29:51:831_R:] OK
[2022-08-24 17:30:00:930_S:] AT+QGNSSRD?
[2022-08-24 17:30:01:050_R:] AT+QGNSSRD?
[2022-08-24 17:30:01:050_R:] +QGNSSRD: $GNRMC,115957.000,V,240822,N,V29
[2022-08-24 17:30:01:113_R:] $GNVTG,N
2E
[2022-08-24 17:30:01:113_R:] $GNGGA,115957.000,0,00,25.5,74
[2022-08-24 17:30:01:176_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:30:01:239_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:30:01:239_R:] $GPGSV,1,1,01,31,42,0
60
[2022-08-24 17:30:01:290_R:] $BDGSV,1,1,02,05,42,45,46,076
[2022-08-24 17:30:01:355_R:] $GNGLL,115957.000,V,N
6A
[2022-08-24 17:30:01:355_R:] OK
[2022-08-24 17:30:07:194_S:] AT+QGNSSRD?
[2022-08-24 17:30:07:305_R:] AT+QGNSSRD?
[2022-08-24 17:30:07:305_R:] +QGNSSRD: $GNRMC,120003.000,V,240822,N,V27
[2022-08-24 17:30:07:368_R:] $GNVTG,N
2E
[2022-08-24 17:30:07:368_R:] $GNGGA,120003.000,0,00,25.5,7A
[2022-08-24 17:30:07:430_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:30:07:494_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:30:07:494_R:] $GPGSV,1,1,02,31,42,32,32,0
63
[2022-08-24 17:30:07:560_R:] $BDGSV,1,1,02,05,40,45,44,076
[2022-08-24 17:30:07:626_R:] $GNGLL,120003.000,V,N
64
[2022-08-24 17:30:07:626_R:] OK
[2022-08-24 17:30:09:983_S:] AT+QGNSSRD?
[2022-08-24 17:30:10:102_R:] AT+QGNSSRD?
[2022-08-24 17:30:10:102_R:] +QGNSSRD: $GNRMC,120006.000,V,240822,N,V22
[2022-08-24 17:30:10:162_R:] $GNVTG,N
2E
[2022-08-24 17:30:10:162_R:] $GNGGA,120006.000,0,00,25.5,7F
[2022-08-24 17:30:10:233_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:30:10:286_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:30:10:286_R:] $GPGSV,1,1,02,31,42,32,32,0
63
[2022-08-24 17:30:10:349_R:] $BDGSV,1,1,02,05,40,45,46,074
[2022-08-24 17:30:10:412_R:] $GNGLL,120006.000,V,N
61
[2022-08-24 17:30:10:412_R:] OK
[2022-08-24 17:30:12:674_S:] AT+QGNSSRD?
[2022-08-24 17:30:12:788_R:] AT+QGNSSRD?
[2022-08-24 17:30:12:788_R:] +QGNSSRD: $GNRMC,120009.000,V,240822,N,V2D
[2022-08-24 17:30:12:858_R:] $GNVTG,N
2E
[2022-08-24 17:30:12:858_R:] $GNGGA,120009.000,0,00,25.5,70
[2022-08-24 17:30:12:922_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:30:12:985_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:30:12:985_R:] $GPGSV,1,1,03,18,23,31,43,32,32,0
6B
[2022-08-24 17:30:13:039_R:] $BDGSV,1,1,02,05,40,45,48,07A
[2022-08-24 17:30:13:103_R:] $GNGLL,120009.000,V,N
6E
[2022-08-24 17:30:13:103_R:] OK
[2022-08-24 17:30:14:230_S:] AT+QGNSSRD?
[2022-08-24 17:30:14:356_R:] AT+QGNSSRD?
[2022-08-24 17:30:14:356_R:] +QGNSSRD: $GNRMC,120010.000,V,240822,N,V25
[2022-08-24 17:30:14:422_R:] $GNVTG,N
2E
[2022-08-24 17:30:14:422_R:] $GNGGA,120010.000,0,00,25.5,78
[2022-08-24 17:30:14:490_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:30:14:553_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:30:14:553_R:] $GPGSV,1,1,03,18,23,31,43,32,32,0
6B
[2022-08-24 17:30:14:616_R:] $BDGSV,1,1,02,05,40,45,47,075
[2022-08-24 17:30:14:680_R:] $GNGLL,120010.000,V,N
66
[2022-08-24 17:30:14:680_R:] OK
[2022-08-24 17:30:17:119_S:] AT+QGNSSRD?
[2022-08-24 17:30:17:229_R:] AT+QGNSSRD?
[2022-08-24 17:30:17:229_R:] +QGNSSRD: $GNRMC,120013.000,V,240822,N,V26
[2022-08-24 17:30:17:291_R:] $GNVTG,N
2E
[2022-08-24 17:30:17:291_R:] $GNGGA,120013.000,0,00,25.5,7B
[2022-08-24 17:30:17:347_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:30:17:410_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:30:17:467_R:] $GPGSV,1,1,03,18,23,31,43,32,31,0
68
[2022-08-24 17:30:17:524_R:] $BDGSV,1,1,02,05,40,45,48,07A
[2022-08-24 17:30:17:524_R:] $GNGLL,120013.000,V,N
65
[2022-08-24 17:30:17:587_R:] OK
[2022-08-24 17:30:26:034_S:] AT+QGNSSRD?
[2022-08-24 17:30:26:145_R:] AT+QGNSSRD?
[2022-08-24 17:30:26:145_R:] +QGNSSRD: $GNRMC,120022.000,V,240822,N,V24
[2022-08-24 17:30:26:208_R:] $GNVTG,N
2E
[2022-08-24 17:30:26:208_R:] $GNGGA,120022.000,0,00,25.5,79
[2022-08-24 17:30:26:271_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:30:26:335_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:30:26:387_R:] $GPGSV,2,1,05,12,26,18,24,25,20,31,45,0
6D
[2022-08-24 17:30:26:450_R:] $GPGSV,2,2,05,32,29,06A
[2022-08-24 17:30:26:450_R:] $BDGSV,1,1,02,05,41,45,47,0
74
[2022-08-24 17:30:26:515_R:] $GNGLL,120022.000,V,N*67
[2022-08-24 17:30:26:515_R:] OK
[2022-08-24 17:30:32:025_S:] AT+QGNSSRD?
[2022-08-24 17:30:32:150_R:] AT+QGNSSRD?
[2022-08-24 17:30:32:150_R:] +QGNSSRD: $GNRMC,120028.000,V,240822,N,V2E
[2022-08-24 17:30:32:212_R:] $GNVTG,N
2E
[2022-08-24 17:30:32:212_R:] $GNGGA,120028.000,0,00,25.5,73
[2022-08-24 17:30:32:276_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:30:32:340_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:30:32:340_R:] $GPGSV,2,1,05,12,24,18,23,25,20,31,45,0
68
[2022-08-24 17:30:32:393_R:] $GPGSV,2,2,05,32,27,064
[2022-08-24 17:30:32:456_R:] $BDGSV,1,1,02,05,41,45,47,0
74
[2022-08-24 17:30:32:456_R:] $GNGLL,120028.000,V,N*6D
[2022-08-24 17:30:32:519_R:] OK
[2022-08-24 17:30:38:613_S:] AT+QGNSSRD?
[2022-08-24 17:30:38:723_R:] AT+QGNSSRD?
[2022-08-24 17:30:38:723_R:] +QGNSSRD: $GNRMC,120034.000,V,240822,N,V23
[2022-08-24 17:30:38:787_R:] $GNVTG,N
2E
[2022-08-24 17:30:38:787_R:] $GNGGA,120034.000,0,00,25.5,7E
[2022-08-24 17:30:38:850_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:30:38:903_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:30:38:965_R:] $GPGSV,2,1,06,06,23,12,22,18,20,25,15,0
6C
[2022-08-24 17:30:39:019_R:] $GPGSV,2,2,06,31,45,32,26,065
[2022-08-24 17:30:39:019_R:] $BDGSV,1,1,02,05,41,45,47,0
74
[2022-08-24 17:30:39:083_R:] $GNGLL,120034.000,V,N*60
[2022-08-24 17:30:39:083_R:] OK
[2022-08-24 17:30:43:457_S:] AT+QGNSSRD?
[2022-08-24 17:30:43:583_R:] AT+QGNSSRD?
[2022-08-24 17:30:43:583_R:] +QGNSSRD: $GNRMC,120039.000,V,240822,N,V2E
[2022-08-24 17:30:43:637_R:] $GNVTG,N
2E
[2022-08-24 17:30:43:637_R:] $GNGGA,120039.000,0,00,25.5,73
[2022-08-24 17:30:43:699_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:30:43:762_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:30:43:816_R:] $GPGSV,2,1,05,06,22,12,22,18,17,31,44,0
6B
[2022-08-24 17:30:43:869_R:] $GPGSV,2,2,05,32,25,066
[2022-08-24 17:30:43:869_R:] $BDGSV,1,1,02,05,40,45,46,0
74
[2022-08-24 17:30:43:934_R:] $GNGLL,120039.000,V,N*6D
[2022-08-24 17:30:43:934_R:] OK
[2022-08-24 17:30:50:658_S:] AT+QGNSSRD?
[2022-08-24 17:30:50:772_R:] AT+QGNSSRD?
[2022-08-24 17:30:50:772_R:] +QGNSSRD: $GNRMC,120046.000,V,240822,N,V26
[2022-08-24 17:30:50:835_R:] $GNVTG,N
2E
[2022-08-24 17:30:50:835_R:] $GNGGA,120046.000,0,00,25.5,7B
[2022-08-24 17:30:50:899_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:30:50:963_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:30:50:963_R:] $GPGSV,2,1,05,06,19,12,22,18,17,31,45,0
62
[2022-08-24 17:30:51:026_R:] $GPGSV,2,2,05,32,23,060
[2022-08-24 17:30:51:088_R:] $BDGSV,1,1,02,05,40,45,47,0
75
[2022-08-24 17:30:51:088_R:] $GNGLL,120046.000,V,N*65
[2022-08-24 17:30:51:153_R:] OK
[2022-08-24 17:30:58:884_S:] AT+QGNSSRD?
[2022-08-24 17:30:59:009_R:] AT+QGNSSRD?
[2022-08-24 17:30:59:009_R:] +QGNSSRD: $GNRMC,120055.000,V,240822,N,V24
[2022-08-24 17:30:59:072_R:] $GNVTG,N
2E
[2022-08-24 17:30:59:072_R:] $GNGGA,120055.000,0,00,25.5,79
[2022-08-24 17:30:59:137_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:30:59:187_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:30:59:254_R:] $GPGSV,2,1,07,06,21,12,23,18,23,22,28,0
64
[2022-08-24 17:30:59:254_R:] $GPGSV,2,2,07,25,18,31,46,32,22,06D
[2022-08-24 17:30:59:319_R:] $BDGSV,1,1,02,05,40,45,47,0
75
[2022-08-24 17:30:59:382_R:] $GNGLL,120055.000,V,N*67
[2022-08-24 17:30:59:382_R:] OK
[2022-08-24 17:31:13:134_S:] AT+QGNSSRD?
[2022-08-24 17:31:13:261_R:] AT+QGNSSRD?
[2022-08-24 17:31:13:261_R:] +QGNSSRD: $GNRMC,120109.000,V,240822,N,V2C
[2022-08-24 17:31:13:312_R:] $GNVTG,N
2E
[2022-08-24 17:31:13:312_R:] $GNGGA,120109.000,0,00,25.5,71
[2022-08-24 17:31:13:375_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:31:13:438_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:31:13:501_R:] $GPGSV,2,1,07,01,22,06,18,18,03,21,28,0
6C
[2022-08-24 17:31:13:501_R:] $GPGSV,2,2,07,22,28,31,46,32,23,068
[2022-08-24 17:31:13:552_R:] $BDGSV,1,1,03,05,40,22,32,45,48,0
7A
[2022-08-24 17:31:13:616_R:] $GNGLL,120109.000,V,N*6F
[2022-08-24 17:31:13:679_R:] OK
[2022-08-24 17:31:15:571_S:] AT+QGNSSRD?
[2022-08-24 17:31:15:681_R:] AT+QGNSSRD?
[2022-08-24 17:31:15:681_R:] +QGNSSRD: $GNRMC,120111.000,V,240822,N,V25
[2022-08-24 17:31:15:732_R:] $GNVTG,N
2E
[2022-08-24 17:31:15:732_R:] $GNGGA,120111.000,0,00,25.5,78
[2022-08-24 17:31:15:795_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:31:15:858_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:31:15:921_R:] $GPGSV,2,1,06,01,21,18,12,21,28,22,28,0
6B
[2022-08-24 17:31:15:983_R:] $GPGSV,2,2,06,31,46,32,23,063
[2022-08-24 17:31:15:983_R:] $BDGSV,1,1,03,05,40,22,32,45,48,0
7A
[2022-08-24 17:31:16:047_R:] $GNGLL,120111.000,V,N*66
[2022-08-24 17:31:16:047_R:] OK
[2022-08-24 17:31:21:490_S:] AT+QGNSSRD?
[2022-08-24 17:31:21:602_R:] AT+QGNSSRD?
[2022-08-24 17:31:21:602_R:] +QGNSSRD: $GNRMC,120117.000,V,240822,N,V23
[2022-08-24 17:31:21:668_R:] $GNVTG,N
2E
[2022-08-24 17:31:21:668_R:] $GNGGA,120117.000,0,00,25.5,7E
[2022-08-24 17:31:21:731_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:31:21:794_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:31:21:857_R:] $GPGSV,2,1,07,01,21,06,22,18,17,21,28,0
63
[2022-08-24 17:31:21:857_R:] $GPGSV,2,2,07,22,29,31,45,32,23,06A
[2022-08-24 17:31:21:920_R:] $BDGSV,1,1,03,05,40,22,33,45,48,0
7B
[2022-08-24 17:31:21:971_R:] $GNGLL,120117.000,V,N*60
[2022-08-24 17:31:22:037_R:] OK
[2022-08-24 17:31:25:828_S:] AT+QGNSSRD?
[2022-08-24 17:31:25:950_R:] AT+QGNSSRD?
[2022-08-24 17:31:25:950_R:] +QGNSSRD: $GNRMC,120122.000,V,240822,N,V25
[2022-08-24 17:31:26:013_R:] $GNVTG,N
2E
[2022-08-24 17:31:26:013_R:] $GNGGA,120122.000,0,00,25.5,78
[2022-08-24 17:31:26:070_R:] $GNGSA,A,1,25.5,25.5,25.5,1
01
[2022-08-24 17:31:26:133_R:] $GNGSA,A,1,25.5,25.5,25.5,404
[2022-08-24 17:31:26:133_R:] $GPGSV,2,1,07,01,21,06,12,18,12,21,28,0
65
[2022-08-24 17:31:26:196_R:] $GPGSV,2,2,07,22,28,31,45,32,22,06A
[2022-08-24 17:31:26:259_R:] $BDGSV,1,1,03,05,40,22,32,45,47,0
75
[2022-08-24 17:31:26:321_R:] $GNGLL,120122.000,V,N*66
[2022-08-24 17:31:26:321_R:] OK
[2022-08-24 17:31:35:499_S:] AT+QGNSSRD=“NMEA/RMC”
[2022-08-24 17:31:35:617_R:] AT+QGNSSRD=“NMEA/RMC”
[2022-08-24 17:31:35:617_R:] +QGNSSRD: $GNRMC,120131.000,V,240822,N,V*27
[2022-08-24 17:31:35:680_R:] OK
[2022-08-24 17:31:37:727_S:] AT+QGNSSRD=“NMEA/RMC”
[2022-08-24 17:31:37:850_R:] AT+QGNSSRD=“NMEA/RMC”
[2022-08-24 17:31:37:850_R:] +QGNSSRD: $GNRMC,120134.000,V,240822,N,V*22
[2022-08-24 17:31:37:913_R:] OK
Hi,I sent you the document by private message, please parse these statements according to the document
