I am sending the command AT+QCFG="band" and in response, I get: +QCFG: "band",0x93,0x1a0080800c5 What does this value mean?
also while there is that value it may change working bands on its own, and the value itself (0x1a0080800c5) won’t change, I can track it with the command AT+QNWINFO, so is it some auto mode?
Bandmasks control the currently supported bands on a modem. The native bandmasks of a particular modem model can be restricted further by removing values, but bands not supported by the modem firmware cannot be added.
The “0x93” is your GW bandmask (for 2G/GSM and 3G/WCDMA) bands.
That’s decoded from a lookup table, where 0x93 decodes as GSM 900 + GSM 1800 + WCDMA 2100 MHz + WCDMA 900 MHz.
