Can I use 3.3V GPIO to drive down PWRKEY_3.0V on quectel umts-lte evb
Could someone let me know if it’s safe for the board to use 3.3V GPIO to driver down PWRKEY_3.0V on quectel umts-lte evb to enable the adapter - documentation metnions the output level is 1.5V but there is a 3.0 test pin so i want to use gpio with 3.3V on high level?
I would like to ask where i can find the schematics of quectel umts-lte evb and BG95-M3-TE-A
Best Regards,
Jakub
Have sent the PDF of the the schematics of quectel umts-lte evb and BG95-M3-TE-A.
Thank you very much - could you tell me if it’s safe to use 3V signal to control PWRKEY via PWRKEY_3.0V pin?
For the EVB you can just test it. For your own product, please check the Hardware design.
Hey. Can you please also send me the PDF
