Can BG95 modem connect to NBIoT RAT, even though iotopmode is set to 0?
I am setting the BG95 modem in iotopmode = 0 configuration. According to the datasheet, it should connect only to eMTC, not NBIoT. however, some devices report NBIoT RAT from the serving cell command. Is it possible that modem may fall back to NBIoT even with iotopmode set to 0?
If you set the value of iotopmode is 0,it is not possible that connect to NBloT.So can you give me the screenshot of the command and I can handle it better.
