Hi!
Where can I find the ca.pl file which is mentioned in this document: https://forums.quectel.com/uploads/short-url/sR1IlxLa0esJDYTQ4EKKsBvVoUO.pdf
Cheers,
Bashar
Hi!
Cheers,
Bashar
Hi, Can anyone please assist me with this?
I’m sorry to reply you so late.
If the ca.pl file is not available, there is an alternative method.
You can manually create folders and files under this path:C:\Program Files\Apache Software Foundation\Apache2.2\bin\demoCA;
1.Create the following folders:certs、private、crl 、newcerts;
2.Create an empty file named index.txt;
3.Create an file named serial, then write the value “01”, and then save exit.
