Hi!
Can anyone please provide carrier aggregation CA-ENDC LTE-CA 5G-CA Document for Quectel RM520F Snapdragon X65 Module.
I am looking for what LTE 4G and NR 5G Bands this Module can aggregate.
Hi!
Dear @Basim
Which series did you use?RM520F-GLBA or others?
Could you please send me the latest firmware for this module?
Versione corrente:
RM520F-BL
Revisione: RM520FBLEAR02A02M4G
Dear @hhdds
As checked internally, it is a customized firmware, I can’t share to you.
Please contact with manufacture of your device to get the firmware.
Hello!
Can you provide documentation for carrier aggregation CA-ENDC LTE-CA 5G-CA for Quectel RM520F-GLBA?
Revision: RM520FGLBAR03A01M4G
Dear @Chelsie_Judson
We can’t share the whole document to you.
Please list which you are interested, I can share part to you.
@silvia Hi Silvia, could you please share the latest NR-CA combos for the RM520FGLBAR03A01M4G firmware? Appreciate your help!
Dear @Campus_Apple
I can’t share whole document.
Please list which you are interested in, I will share with you.
Hi Silvia,
Understood. Could you please help check if this firmware version supports the following specific NR-CA combinations:
2CC Inter-band:
CA_n41A-n79A3CC / 300MHz Potential Combos:
CA_n78D
CA_n41C-n79A
CA_n28A-n41A-n79A
If available, could you also confirm the maximum aggregation bandwidth supported for these combos?
Thanks!
Dear @Campus_Apple
I have sent to you via Message, only support CA_n41A-n79A .
