@lei_ming Many thanks for the pictures! What is the brown wire you have soldered to the PCB?
I was meanwhile able to connect to DEBUG UART RX/TX (needed to buy a 1.8V level USB ↔ Seriell converter) and can also send characters to the module, when during booting I press “Newline”, I see a login and prompt, no password needed on this device (perhaps due to early version of the firmware?):
Please press Enter to activate this console.
BusyBox v1.35.0 (2024-04-19 01:33:15 UTC) built-in shell (ash)
_______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
OpenWrt 22.03.5, r20134-5f15225c1e
=== WARNING! =====================================
There is no root password defined on this device!
Use the "passwd" command to set up a new password
in order to prevent unauthorized SSH logins.
root@(none):/#
root@(none):/#
After around 30s I get:
[ 31.276653][ T5290] qbi: Wakelock support is enabled
[ 31.331740][ T5290] qbi:android_mbim node is up for I/O
[ 32.191600][ T5990] /etc/init.d/start_quectel_slic_daemon start
Format: Log Type - Time(microsec) - Message - Optional Info
Log Type: B - Since Boot(Power On Reset), D - Delta, S - Statistic
S - QC_IMAGE_VERSION_STRING=BOOT.MXF.2.3-00432-PINNACLES-1
S - IMAGE_VARIANT_STRING=SocPinnaclesLE
S - OEM_IMAGE_VERSION_STRING=ip-10-195-201-16
S - Boot Interface: NAND
S - Secure Boot: Off
S - Boot Config @ 0x221c8600 = 0x00000009
S - JTAG ID @ 0x221c8744 = 0x001f50e1
S - OEM ID @ 0x221c8700 = 0x00000000
S - Serial Number @ 0x221c8610 = 0x0000044391e4b69a
S - OEM Config Row 0 @ 0x221c2108 = 0x0000000000000000
S - OEM Config Row 1 @ 0x221c2110 = 0x0000000000000000
S - Feature Config Row 0 @ 0x221c2128 = 0x241b850000018000
S - Feature Config Row 1 @ 0x221c2130 = 0x59995500a096a504
S - OEM LCS:PROD
S - Core 0 Frequency, 1516 MHz
S - PBL Patch Ver: 7
S - PBL freq: 600 MHZ
S - -------------------------
PBL Timestamps (in usecs)
APBL start: 340
APBL Boot Media Detect Start: 6850
APBL Boot Media Detect End: 7013
APBL SHELF Load+Auth Start: 7015
APBL ELF MD Load Start: 10348
APBL ELF MD Load End: 11118
APBL ELF Seg Load Start: 11118
APBL ELF Seg Load End: 59943
APBL SEQ Valid Set: 59963
APBL SEQ SA ACK Rcvd: 61975
APBL ELF MD Load Start: 62370
APBL ELF MD Load End: 66278
APBL ELF Auth Start: 66281
APBL ELF Auth End: 76151
APBL ELF Seg Load Start: 76153
APBL ELF Seg Load End: 118965
APBL ELF Seg Verify Start: 118965
APBL ELF Seg Verify End: 124168
APBL ELF MD Load Start: 124525
APBL ELF MD Load End: 128765
APBL ELF Auth Start: 128766
APBL ELF Auth End: 138658
APBL ELF Seg Load Start: 138660
APBL ELF Seg Load End: 340688
APBL ELF Seg Verify Start: 340690
APBL ELF Seg Verify End: 346425
APBL SHELF Load+Auth End: 346471
APBL TME PBL Exit: 346473
APBL XBL_SC Exit Check: 347116
APBL XBL_SC Exit Ack: 356183
APBL Exit: 356185
B - 357765 - SBL1, Start
B - 546346 - SBL1 BUILD @ 10:32:47 on Mar 13 2024
B - 553270 - usb: usb_eud_serial , 0x91e4b69a
D - 702 - sbl1_hw_init
B - 581116 - RBOOT: media open fail
B - 581147 - RBOOT : recoveryinfo unavailable
D - 0 - init_edl_pcie
D - 0 - blacklist disable
B - 591944 - OEM_MISC - Image Load, Start
D - 2623 - Auth Metadata
D - 33489 - OEM_MISC - Image Loaded, Delta - (5592 Bytes)
B - 625829 - QTI_MISC - Image Load, Start
D - 9974 - Auth Metadata
D - 20130 - QTI_MISC - Image Loaded, Delta - (4624 Bytes)
B - 646600 - APDP - Image Load, Start
D - 2592 - Auth Metadata
D - 16866 - APDP - Image Loaded, Delta - (4440 Bytes)
D - 0 - boot_dload_dump_security_regions
D - 0 - EUD Init
D - 0 - blacklist enable
B - 678411 - Debug Policy: processed
B - 678686 - Debug Policy: no debug policy applied
D - 6710 - DP_Milestone
D - 3447 - Auth Metadata
D - 8815 - Open XBL Config 1st
B - 696284 - XBL Config - Image Load, Start
B - 703696 - DTB Found: [pre-ddr][89026101000000][0]
D - 4361 - boot_pre_ddr_dtb_load
D - 2471 - tsens_init_if
D - 61 - boot_check_device_temp
B - 719647 - PMIC A:2.1 B:2.0
B - 722087 - PM: Reset by PSHOLD
B - 722697 - PM: Reset Type: Warm Reset
B - 726022 - PM: Reset Type: Warm Reset
B - 729956 - PM: Warm reset count:0x3
B - 733891 - PM: Reset by PSHOLD
B - 737642 - PM: Reset Type: Warm Reset
B - 740936 - PM: Reset Type: Warm Reset
B - 744871 - PM: Warm reset count:0x2
B - 748805 - PM: Reset by PSHOLD
B - 752557 - PM: Reset Type: Warm Reset
B - 755881 - PM: Reset Type: Warm Reset
B - 759816 - PM: Warm reset count:0x1
B - 773998 - PM: SET_VAL:Skip
B - 774151 - PM: PSI: b0x04_v0x25
B - 780922 - PM: OEM_PSI Start
B - 781684 - PM: OEM_PSI Done
B - 785558 - PM: Device Init # SPMI Transn: 1029
D - 71736 - pm_device_init, Delta
B - 791871 - pm_driver_init, Start
B - 801448 - PM: Driver Init # SPMI Transn: 484
D - 6131 - pm_driver_init, Delta
D - 90707 - sbl1_pmic_init
D - 1403 - media_init:2
D - 0 - media_init:3
D - 183 - boot_wdog_disable_check
D - 30 - Closing XBL Config 1st
D - 153 - init-logstomedia
D - 0 - shrm_load_cancel
B - 828136 - SHRM - Image Load, Start
B - 843264 - CDT image has been loaded from : NAND
D - 12139 - boot_cdt_init
B - 848205 - CDT - Image Load, Start
B - 850980 - CDT Version:3,Platform ID:34,Major ID:1,Minor ID:0,Subtype:4
D - 3935 - sbl1_hw_platform_pre_ddr
B - 861686 - Pre_DDR_clock_init, Start
D - 31 - Pre_DDR_clock_init, Delta
D - 7625 - sbl1_ddr_set_params
D - 3386 - Auth Metadata
D - 7900 - Open XBL Config 2nd
B - 881663 - PM: CHG Init # SPMI Transn: 2 Error Flag 0
B - 884957 - vsense_init, Start
D - 0 - vsense_init, Delta
D - 38979 - sbl1_hw_pre_ddr_init
D - 213 - boot_fedl_check
D - 0 - boot_dload_handle_forced_dload_timeout
B - 926986 - sbl1_ddr_init, Start
B - 932019 - Mem ID = 0
B - 935374 - LP4/5 DDR detection started
B - 937875 - LP4 DDR detected
B - 941901 - Varient : LE , byte swap : FALSE
B - 944951 - PASS1 Cookie = 0xcafe1111
B - 949495 - HAL_DDR_SDI_Recover() start: DBG PDC Tr = 0x1, First Pass expire = 0x0, First Pass complete = 0x1 , BIMC Alt ARES = 0x0 , PASS2 Cookie = 0xcafecab0
B - 953460 - SHRM run state = 0x10
B - 968466 - HAL_DDR_SDI_Recover() end : DBG PDC Tr = 0x1, First Pass expire = 0x0, First Pass complete = 0x1 , BIMC Alt ARES = 0x0 , PASS2 Cookie = 0xcafebabe
B - 972004 - SHRM run state = 0x10
B - 986736 - ddr_init status = 0 DDR recover normal pass2
D - 58347 - sbl1_ddr_init, Delta
D - 68991 - sbl1_ddr_init
B - 999332 - XBL Config - Image Load, Start
D - 30 - Closing XBL Config 2nd
B - 1006500 - DDR - Image Load, Start
D - 0 - store-logstomedia
B - 1014003 - do_ddr_training, Start
D - 0 - do_ddr_training, Delta
D - 6710 - xbl_trng_ddi_seq
D - 183 - sbl1_check_and_set_turbo_clk
D - 3385 - Auth Metadata
D - 7899 - Open XBL Config 3rd
D - 458 - xbl_map_smem
D - 31 - boot_smem_debug_init
D - 0 - boot_smem_init
D - 1068 - boot_ddr_share_data_to_aop
D - 31 - boot_populate_ddr_details_shared_table
D - 0 - boot_update_ram_partition_table
B - 1059997 - Pimem init cmd, entry
D - 61 - Pimem init cmd, exit
B - 1069513 - External heap init, Start
B - 1071282 - External heap init, End
D - 19001 - sbl1_post_ddr_init
D - 0 - sbl1_hw_init_secondary
B - 1082231 - XBL Config - Image Load, Start
B - 1090466 - DTB Found: [post-ddr][89026101000000][2204010000000000]
D - 4697 - boot_post_ddr_dtb_load
D - 0 - Closing XBL Config 3rd
B - 1100684 - usb: ser_str_cookie_pid - 91e4b69a
D - 3568 - boot_usb_update_serial
B - 1109071 - usb: ldr , 0x2e1
B - 1112487 - usb: qusb_dci_eud_init
D - 6619 - boot_usb_handle_charger
D - 61 - sbl1_hw_platform_smem
B - 1122766 - TCSR reg value 0x10
D - 3477 - ramdump_load_cancel
B - 1129659 - RamDump - Image Load, Start
D - 3142 - Auth Metadata
D - 77958 - RamDump - Image Loaded, Delta - (758632 Bytes)
B - 1207647 - boot_dload_entry
B - 1213656 - SBL1, End
D - 858697 - SBL1, Delta
S - Flash Throughput, 9805 KB/s (843268 Bytes, 86132 us)
S - DDR Frequency, 200 MHz
B - 1270752 - RAMDUMP BUILD @ 15:55:24 on Apr 12 2024
B - 1282281 - PM: Driver Init # SPMI Transn: 484
B - 1284660 - Couldn't read battery voltage, setting threshlod TRUE
B - 1286947 - Display Init Failed
B - 1293261 - RamDump DisplayInfo fail, Errcode:0x1019
B - 1296890 - OCIMEM.BIN
B - 1301740 - CODERAM.BIN
B - 1304241 - DATARAM.BIN
B - 1306864 - MSGRAM0.BIN
B - 1309456 - MSGRAM1.BIN
B - 1312049 - MSGRAM2.BIN
B - 1314641 - MSGRAM3.BIN
B - 1317234 - MSGRAM4.BIN
B - 1319826 - MSGRAM5.BIN
B - 1322449 - MSGRAM6.BIN
B - 1325042 - MSGRAM7.BIN
B - 1327634 - SHRM_MEM.BIN
B - 1330227 - DCC_SRAM.BIN
B - 1332911 - DCC_CFG.BIN
B - 1335595 - CD_STRCT.BIN
B - 1338218 - CD_BTDDR.BIN
B - 1340902 - CD_BTIMM.BIN
B - 1343586 - CD_SHIMM.BIN
B - 1346270 - CPUCPFW.BIN
B - 1348954 - FSM_STS.BIN
B - 1351546 - FSM_CTRL.BIN
B - 1354139 - RST_STAT.BIN
B - 1356823 - PMIC_PON.BIN
B - 1359537 - PMON_HIS.BIN
B - 1362221 - PBUS_LOG.BIN
B - 1364905 - IPA_IU.BIN
B - 1367589 - IPA_SRAM.BIN
B - 1370090 - IPA_HRAM.BIN
B - 1372774 - IPA_MBOX.BIN
B - 1375458 - IPA_GSI.BIN
B - 1378142 - IPA_SEQ.BIN
B - 1380765 - sbl_pmic_dump.bin
B - 1383358 - DDRCS0_0.BIN
B - 1386469 - XBL_LOG.BIN
B - 1389153 - SMEMINFO.BIN
B - 1391776 - SMEM_VER.BIN
B - 1394460 - load.cmm
B - 1421574 - Boot device check, skipping [0]
B - 1421574 - Boot device check, skipping [1]
B - 1425966 - Boot device check, skipping [2]
B - 1430328 - Boot device check, skipping [3]
B - 1434964 - get rd_format_if.init failed
B - 1439081 - Boot device check, skipping [5]
B - 1443199 - Boot device check, skipping [6]
B - 1447560 - Boot device check, skipping [7]
B - 1452196 - HFAT Dump Init
B - 1456436 - SD Dump Init
B - 1711080 - SD Card not present
B - 1711111 - rd_media_if.media_hw_init
B - 1714435 - usb: init start
B - 1718461 - usb: qusb_platform , 0x22
B - 1723829 - usb: usb3phy: PRIM success
B - 1726269 - usb: ID:0x108, value: 0x2190
B - 1728984 - usb: timer_start , 0x4c4b40
B - 1733132 - usb: ID:0xe0, value: 0x1
B - 1737127 - usb: VBUS High!
B - 1741123 - usb: SUPER , 0x122
B - 1951878 - usb: ID:0x20d, value: 0x0
B - 1974143 - usb: ENUM success
B - 1974143 - Sahara Init
B - 1977315 - Sahara Open
B - 2002416 - usb: clear_ep_halt , 0x11
B - 2002660 - usb: resubmit urb , 0x11
B - 2006656 - usb: clear_ep_halt , 0x10
Entering some common commands seems to work, but I have only a few seconds on booting to enter command before it stalls:
root@OpenWrt:/#
root@OpenWrt:/#
root@OpenWrt:/#
root@OpenWrt:/#
root@OpenWrt:/# ls
bin etc mnt rom system usrdata
cache firmware overlay root systemrw var
data lib persist sbin tmp www
dev lib64 proc sys usr
root@OpenWrt:/# mount
ubi0:rootfs on / type ubifs (ro,relatime,bulk_read,assert=read-only,ubi=0,vol=0)
sysfs on /sys type sysfs (rw,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,noatime)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
tmpfs on /dev type tmpfs (rw,nosuid,noexec,noatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,noatime,gid=5,mode=620,ptmxmode=000)
/dev/ubi1_0 on /firmware type ubifs (ro,relatime,bulk_read,assert=read-only,ubi=1,vol=0)
ubi0:persist on /persist type ubifs (rw,relatime,bulk_read,assert=read-only,ubi=0,vol=4)
ubi0:cachefs on /cache type ubifs (rw,relatime,bulk_read,assert=read-only,ubi=0,vol=2)
ubi0:systemrw on /overlay type ubifs (rw,relatime,bulk_read,assert=read-only,ubi=0,vol=3)
/dev/ubi0_1 on /data type ubifs (rw,relatime,bulk_read,assert=read-only,ubi=0,vol=1)
overlay on /etc type overlay (rw,relatime,lowerdir=/etc,upperdir=/overlay/etc-upper,workdir=/overlay/.etc-work)
none on /sys/kernel/config type configfs (rw,relatime)
adb on /dev/usb-ffs/adb type functionfs (rw,relatime)
diag on /dev/ffs-diag type functionfs (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,noatime)
bpffs on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,noatime,mode=700)
pstore on /sys/fs/pstore type pstore (rw,noatime)
tracefs on /sys/kernel/debug/tracing type tracefs (rw,noatime)
binder on /dev/binderfs type binder (rw,relatime,max=1048576)
root@OpenWrt:/# top
Mem: 362432K used, 213680K free, 44K shrd, 0K buff, 173144K cached
CPU: 0% usr 28% sys 0% nic 68% idle 0% io 2% irq 0% sirq
Load average: 1.01 0.24 0.08 3/362 5161
PID PPID USER STAT VSZ %VSZ %CPU COMMAND
3670 1 root R 2904 1% 24% {S15init-mss.ini} /bin/sh /etc/rc.comm
5159 456 root R 2784 0% 2% top
2037 2034 radio S 20984 4% 0% /usr/bin/QCMAP_ConnectionManager /etc/
1749 1724 system S 13684 2% 0% /usr/bin/qwesd
3260 1 root S 12788 2% 0% /usr/bin/QCMAP_Ref_Daemon
1834 1 system S 11712 2% 0% /usr/bin/qseecomd
1884 1 system S 8380 1% 0% /usr/bin/ssgtzd
1788 1784 system S 8200 1% 0% /usr/bin/diag-router
2885 1 radio S 7644 1% 0% /usr/bin/ipacmdiag
2620 2616 root S 7596 1% 0% /usr/bin/port-bridge at_mdm0 at_usb0 0
2622 2617 root S 7596 1% 0% /usr/bin/port-bridge smd7 at_usb2 1
2106 1 adb S 4588 1% 0% /sbin/adbd
1945 1941 system S 3784 1% 0% /usr/bin/time_daemon
3666 1 system S 3320 1% 0% /usr/bin/servicemanager
3571 1 ubi S 3228 1% 0% /usr/sbin/fs-scrub-daemon
1414 1 root S 2844 0% 0% /usr/sbin/msm-irqbalance -f /etc/msm_i
456 1 root S 2748 0% 0% /bin/ash --login
5161 5160 root R 2748 0% 0% /bin/pidof /usr/bin/diag-router
5160 1 root S 2740 0% 0% {diag-script} /bin/sh /etc/initscripts
^C724 1 root S 2604 0% 0% {/usr/bin/qwesd} /sbin/ujail -t 5 -n /
root@OpenWrt:/#
Is there something to enter, which could bring me to EDL?
E.g. a
reboot edl
or so…?
I assume I can execute at least one or two AT commands.
Perhaps there a command to go to EDL?
Perhaps some process to kill, which gives me more time to investigate,
what to do in this state, to avoid it stalls after a few seconds…?
@silvia @Jonathan.wang @herbert.pan-Q
