My BG96 module shows a couple MBN files by AT+QMBNCFG=“LIST”.
However, the module works even all of the MBN files are not selected nor activated.
Is it ok to not select any MBN file?
When should I select and activate a MBN file?
MBN file is a package for dedicate operator ,like AT&T , verizon , and common etc,
Nomally , module will select the right MBN file automatically , if you can register network normally , you do not need to care about it .
To disable MBN file , you can use the below AT cmd
AT+QMBNCFG=“Autosel”,0
AT+QMBNCFG=“Deactivate”
