Hi everyone,
I’m testing PSM (in South Africa) with manual AT commands.I can confirm that I’m connected to the NB1 network with an at+cereg=2 and *at+cereg?" poll. The modem responds with +CEREG: 2,5,“5209”,“E0B8D17”,9. Polling with at+qnwinfo I get the response +QNWINFO: “CAT-NB1”,“65501”,“LTE BAND 8”,3596
I enable the PSM entering indication with at+qcfg=“psm/urc”,1. Then I try to enable PSM with at+cpsms=1,“10101010”,“00100001”.
The problem is that I never get a URC +QPSMTIMER: <tau_timer>,<T3324_timer>. Could it be that the network does not support PSM? Is there an AT command to confirm this?
If I use at+cereg=4 and poll using at+cereg? I get an ERROR response.
For the record, the BG96 FW revision is BG96MAR04A03M1G
Thanks in advance,
Pieter
