Hi, I’ve encountered problem with BG96 module. I’m trying to connect to nbiot network and then open TCP socket to server. I have around 60 devices reporting their status once per day.The solution I’ve had worked nearly three quarters of the year, but suddenly I’ve started noticing errors when trying to open TCP socket. There was no change on the FW of BG96 nor the application driving it. I’m encountering this error in about half of the connection attempts.
Here is the log after BG96 powerup:
[LTE] I : sendCmd - —> :AT+CFUN=4
[LTE] I : parseResponse - Parsed msg:
OK[LTE] I : sendCmd - —> :AT+GSN
866770054173639OK
[LTE] I : sendCmd - —> :AT+QGMR
BG96MAR02A07M1G_01.018.01.018OK
[LTE] I : sendCmd - —> :AT+CMEE=2
OK[LTE] I : sendCmd - —> :AT+QSIMSTAT?
+QSIMSTAT: 0,1OK
[LTE] I : initSIM - Sim card present
[LTE] I : sendCmd - —> :AT+CPIN?
+CPIN: READYOK
[LTE] I : initSIM - Sim card status - READY
[LTE] I : sendCmd - —> :AT+QCCID
+QCCID: [correct SIM_CCID]OK
[LTE] I : sendCmd - —> :AT+QCSCON?
+QCSCON:0,0OK
[LTE] I : sendCmd - —> :AT+QCFG=“nwscanseq”,03,1
OK[LTE] I : sendCmd - —> :AT+QCFG=“nwscanmode”,3,1
OK[LTE] I : sendCmd - —> :AT+QCFG=“iotopmode”,1,1
OK[LTE] I : sendCmd - —> :AT+QICSGP=1,1,“nbiot.telekom.sk”,“”,“”,1
OK[LTE] I : sendCmd - —> :AT+CGDCONT=1,“IP”,“”
OK[LTE] I : sendCmd - —> :AT+QCSCON?
+QCSCON:0,0OK
[LTE] I : sendCmd - —> :AT+CFUN=1
OK[LTE] I : sendCmd - —> :AT+COPS=1,2,“23102”,9
+QCSCON:0,1OK
[LTE] I : sendCmd - —> :AT+CEREG?
+CEREG: 0,5OK
[LTE] I : sendCmd - —> :AT+CGPADDR
+CGPADDR: 1,10.234.72.165OK
+QCSCON:0,1OK
[LTE] I : sendCmd - —> :AT+QIACT=1
+QCSCON:0,1OK
[LTE] I : sendCmd - —> :AT+QIOPEN=1,0,“TCP”,“[SERVER_IP]”,[SERVER_PORT],0,2
Then after a long time (about 150seconds as stated in DS) I receive ERROR 566 - Socket connect failed.
On the server side I cannot see even TCP SYN.
Only solution to get things working is to repeat whole process.
I’ve tryied AT+QPING, but this resulted also in error.
SIM card is 100% working as I have used it before. Server is also working flawlessly.
Does anyone have an idea how to correct things or at least debug it to lower level ? Thanks in advance.
