I was trying to use QFlash for Linux to update FM on BG96. and I got the following error. I only copied in QFlash executable into linux (no fastboot or firehose folders copied).
I am root in Linux and have already tried power off/on the modem. Any idea what would go wrong? Thanks!
ls
BG96MAR02A08M1G_01.013.01.013
QFlash -f BG96MAR02A08M1G_01.013.01.013/ -m 0
[10-15_13:11:29:423] QFlash Version: LTE<E-A_QFlash_Linux&Android_V2.0.0
[10-15_13:11:29:424] Builded at: Sep 5 2020 19:10:00
sh: dpkg: command not found
[10-15_13:11:29:472] Host runtime enviroment check ok
[10-15_13:11:29:473]
[10-15_13:11:29:473] The CPU is little endian
[10-15_13:11:29:474] Warn: Fail to open pipe “/data/update.conf”
[10-15_13:11:29:474] Warn: If you want to the feature of ‘upgrate progress’, you need to read “/data/update.conf”
[10-15_13:11:29:474] Module upgrade tool, Fri Oct 15 13:11:29 2021
[10-15_13:11:29:485] Auto detect quectel diagnose port = ttyUSB0
[10-15_13:11:29:486] Detect /data/modem-fw/BG96MAR02A08M1G_01.013.01.013//md5.txt file.
[10-15_13:11:29:487] md5 checking enable.
[10-15_13:11:29:489] md5 checking: /data/modem-fw/BG96MAR02A08M1G_01.013.01.013//contents.xml pass
[10-15_13:11:29:511] md5 checking: /data/modem-fw/BG96MAR02A08M1G_01.013.01.013//update/partition_nand.xml pass
[10-15_13:11:29:541] md5 checking: /data/modem-fw/BG96MAR02A08M1G_01.013.01.013//update//sbl1.mbn pass
[10-15_13:11:29:542] md5 checking: /data/modem-fw/BG96MAR02A08M1G_01.013.01.013//update//partition.mbn pass
[10-15_13:11:29:591] md5 checking: /data/modem-fw/BG96MAR02A08M1G_01.013.01.013//update//tz.mbn pass
[10-15_13:11:29:613] md5 checking: /data/modem-fw/BG96MAR02A08M1G_01.013.01.013//update//mba.mbn pass
[10-15_13:11:29:625] md5 checking: /data/modem-fw/BG96MAR02A08M1G_01.013.01.013//update//acdb.mbn pass
[10-15_13:11:29:640] md5 checking: /data/modem-fw/BG96MAR02A08M1G_01.013.01.013//update//rpm.mbn pass
[10-15_13:11:31:674] md5 checking: /data/modem-fw/BG96MAR02A08M1G_01.013.01.013//update//qdsp6sw.mbn pass
[10-15_13:11:32:026] md5 checking: /data/modem-fw/BG96MAR02A08M1G_01.013.01.013//update//apps.mbn pass
[10-15_13:11:32:027] md5 checking: /data/modem-fw/BG96MAR02A08M1G_01.013.01.013//update//sec.dat pass
[10-15_13:11:32:030] md5 checking: /data/modem-fw/BG96MAR02A08M1G_01.013.01.013//update//efs2apps.mbn pass
[10-15_13:11:32:041] md5 checking: /data/modem-fw/BG96MAR02A08M1G_01.013.01.013//update//NPRG9x06.mbn pass
[10-15_13:11:32:050] md5 checking: /data/modem-fw/BG96MAR02A08M1G_01.013.01.013//update//ENPRG9x06.mbn pass
[10-15_13:11:32:051] Warn: firehose direcotry missing, firehose upgarde not supported
[10-15_13:11:32:051] Warn: try to continue using method 0…
[10-15_13:11:32:051] file total size: 29188723
[10-15_13:11:32:053] module platform : 9X06
[10-15_13:11:32:056] product model = Quectel
[10-15_13:11:32:064] Start to open com port: /dev/ttyUSB0
[10-15_13:11:32:068] Use normal diag port
[10-15_13:11:32:068] Get sahara hello packet!
[10-15_13:11:34:075] Error: Timeout Occured, No response or command came from the target!
[10-15_13:11:34:075] Error: Get sahara hello packet failed.
[10-15_13:11:34:076] Detect module status!
[10-15_13:11:34:076] Module status detect
[10-15_13:11:37:095] Error: Timeout Occured, No response or command came from the target!
[10-15_13:11:37:095] Error: send_sync read nothing
[10-15_13:11:42:125] Error: Timeout Occured, No response or command came from the target!
[10-15_13:11:42:125] Error: send_sync read nothing
[10-15_13:11:47:155] Error: Timeout Occured, No response or command came from the target!
[10-15_13:11:47:155] Error: send_sync read nothing
[10-15_13:11:52:185] Error: Timeout Occured, No response or command came from the target!
[10-15_13:11:52:185] Error: send_sync read nothing
[10-15_13:11:57:215] Error: Timeout Occured, No response or command came from the target!
[10-15_13:11:57:215] Error: send_sync read nothing
[10-15_13:12:02:245] Error: Timeout Occured, No response or command came from the target!
[10-15_13:12:02:245] Error: send_sync read nothing
[10-15_13:12:07:275] Error: Timeout Occured, No response or command came from the target!
[10-15_13:12:07:275] Error: send_sync read nothing
[10-15_13:12:12:305] Error: Timeout Occured, No response or command came from the target!
[10-15_13:12:12:305] Error: send_sync read nothing
[10-15_13:12:17:335] Error: Timeout Occured, No response or command came from the target!
[10-15_13:12:17:335] Error: send_sync read nothing
[10-15_13:12:22:365] Error: Timeout Occured, No response or command came from the target!
[10-15_13:12:22:365] Error: send_sync read nothing
[10-15_13:12:22:365] Error: Module status is unspecified, download failed!
[10-15_13:12:22:475] Error: Upgrade module unsuccessfully, Fri Oct 15 13:12:22 2021
[10-15_13:12:22:475] Error: 1. Check whether the path is valid(no bash keywords)
[10-15_13:12:22:475] Error: 2. Poweroff the device before restart upgrade
[10-15_13:12:22:475] Error: 3. Do you have the authority to do upgrade
[10-15_13:12:22:476] Error: 4. Power off/on the modem before do upgrade, if you failed previously.
