i’m use platformio + bg96
ThreadX BG96 - MAIN
Created on: 01.01.2019
Author: Georgi Angelov
http://www.wizio.eu/
https://github.com/Wiz-IO/platform-quectel
#include <_ansi.h>
#include <stddef.h>
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include <stdlib.h>
#include <stdarg.h>
#include <math.h>
#include <qapi.h>
#include <qapi_uart.h>
#include <qapi_timer.h>
#include <qapi_atfwd.h>
#include <qapi_gpioint.h>
#include <quectel_gpio.h>
#include <quectel_utils.h>
#include <quectel_uart_apis.h>
typedef unsigned char boolean;
typedef unsigned char uint8;
#define QUEC_AT_RESULT_ERROR_V01 0 /< Result ERROR.
This is to be set in case of ERROR or CME ERROR.
The response buffer contains the entire details. */
#define QUEC_AT_RESULT_OK_V01 1 /< Result OK. This is to be set if the final response
must send an OK result code to the terminal.
The response buffer must not contain an OK. */
#define QUEC_AT_MASK_EMPTY_V01 0 /< Denotes a feed back mechanism for AT reg and de-reg */
#define QUEC_AT_MASK_NA_V01 1 /< Denotes presence of Name field */
#define QUEC_AT_MASK_EQ_V01 2 /< Denotes presence of equal (=) operator */
#define QUEC_AT_MASK_QU_V01 4 /< Denotes presence of question mark (?) */
#define QUEC_AT_MASK_AR_V01 8 /**< Denotes presence of trailing argument operator */
static char *rx_buff = NULL;
static char *tx_buff = NULL;
static QT_UART_CONF_PARA uart_conf;
static int qexample_val = 0;
FUNCTION
static int qt_atoi(char *str)
int res = 0, i;
for (i = 0; str[i] != '\0' && str[i] != '.'; ++i)
res = res*10 + (str[i] - '0');
return res;
void *_sbrk(intptr_t increment) { return (void *)-1; }
void abort(void)
while (1) // dont block app
qt_uart_dbg(uart_conf.hdlr, “\nabort”);
qapi_Timer_Sleep(100, QAPI_TIMER_UNIT_SEC, 1);
TX_BYTE_POOL *heap;
static char heap_buffer[HEAP]; // build_flags = -D HEAP=xxx
void heap_init(void)
if (txm_module_object_allocate(&heap, sizeof(TX_BYTE_POOL)))
abort();
if (tx_byte_pool_create(heap, “heap_byte_pool”, heap_buffer, HEAP))
abort();
int quectel_dbg_uart_init(qapi_UART_Port_Id_e port_id)
if (tx_byte_allocate(heap, (VOID *)&rx_buff, 4 * 1024, TX_NO_WAIT))
abort();
if (tx_byte_allocate(heap, (VOID *)&tx_buff, 4 * 1024, TX_NO_WAIT))
abort();
uart_conf.hdlr = NULL;
uart_conf.port_id = port_id;
uart_conf.tx_buff = tx_buff;
uart_conf.tx_len = sizeof(tx_buff);
uart_conf.rx_buff = rx_buff;
uart_conf.rx_len = sizeof(rx_buff);
uart_conf.baudrate = 115200;
uart_init(&uart_conf); // open uart
return TX_SUCCESS;
void atfwd_cmd_handler_cb(boolean is_reg, char atcmd_name,
uint8 at_fwd_params, uint8 mask,
uint32 at_handle)
char buff[32] = {0};
int tmp_val = 0;
qapi_Status_t ret = QAPI_ERROR;
qt_uart_dbg(uart_conf.hdlr,"atfwd_cmd_handler_cb is called, atcmd_name:[%s] mask:[%d]\n", atcmd_name, mask);
qt_uart_dbg(uart_conf.hdlr,"atfwd_cmd_handler_cb is called, is_reg:[%d]\n", is_reg);
if(is_reg) //Registration Successful,is_reg return 1
if(mask==QUEC_AT_MASK_EMPTY_V01)
qt_uart_dbg(uart_conf.hdlr,"Atcmd %s is registered\n",atcmd_name);
return;
if( !strncasecmp(atcmd_name, "+QEXAMPLE",strlen(atcmd_name)) )
//Execute Mode
if ((QUEC_AT_MASK_NA_V01) == mask)//AT+QEXAMPLE
ret = qapi_atfwd_send_resp(atcmd_name, "", QUEC_AT_RESULT_OK_V01);
//Read Mode
else if ((QUEC_AT_MASK_NA_V01 | QUEC_AT_MASK_QU_V01) == mask)//AT+QEXAMPLE?
snprintf(buff, sizeof(buff), "+QEXAMPLE: %d", qexample_val);
ret = qapi_atfwd_send_resp(atcmd_name, buff, QUEC_AT_RESULT_OK_V01);
//Test Mode
else if ((QUEC_AT_MASK_NA_V01 | QUEC_AT_MASK_EQ_V01 | QUEC_AT_MASK_QU_V01) == mask)//AT+QEXAMPLE=?
snprintf(buff, sizeof(buff), "+QEXAMPLE: (0-2)");
//Write Mode
else if ((QUEC_AT_MASK_NA_V01 | QUEC_AT_MASK_EQ_V01 | QUEC_AT_MASK_AR_V01) == mask)//AT+QEXAMPLE=<value>
tmp_val = qt_atoi((char*)at_fwd_params);
if(tmp_val >= 0 && tmp_val <= 2)
qexample_val = tmp_val;
else
ret = qapi_atfwd_send_resp(atcmd_name, "", QUEC_AT_RESULT_ERROR_V01);
else
qt_uart_dbg(uart_conf.hdlr,"[%s] send resp, ret = %d\n", atcmd_name, ret);
attribute((section(".library"))) int TXM_MODULE_THREAD_ENTRY(void)
qapi_Status_t retval = QAPI_ERROR;
heap_init();
if (quectel_dbg_uart_init(QAPI_UART_PORT_002_E)) // QAPI_UART_PORT_002_E —> EVB COM2(DEBUG)
abort();
qt_uart_dbg(uart_conf.hdlr, “\nThreadX BG96 Hello World”);
retval = qapi_atfwd_reg("+QEXAMPLE", atfwd_cmd_handler_cb);
if(retval != QAPI_OK)
qt_uart_dbg(uart_conf.hdlr,"qapi_atfwd_reg fail\n");
else
qt_uart_dbg(uart_conf.hdlr,"qapi_atfwd_reg ok!\n");
while (1)
qt_uart_dbg(uart_conf.hdlr, "LOOP");
tx_thread_sleep(500); // only here or qapi_Timer_Sleep()
qapi_Timer_Sleep
COM2(DEBUG) ouput
atfwd_cmd_handler_cb is called, atcmd_name:[+QEXAMPLE] mask:[1]
qapi_atfwd_reg ok!
atfwd_cmd_handler_cb is called, is_reg:[0]
why is_reg is 0 ??
COM1(MAIN)
RDY
APP RDY
AT+QEXAMPLE
ERROR
AT+QEXAMPLE?
ERROR
AT+QEXAMPLE=1
ERROR
