Im working with BG96 and sending data via MQTT protocol to the server.
In according with this document:
Rev. BG96&BC95-G&EG9x&UG9x&M95_Compatible_Design_V1.0
If turning off module by PWRKEY causes that the modem is logging out from the network?
yes , if you turn off by hw powerkey , the network will be de-registered ,
i guess you need the PSM feature , under PSM mode poweroff ,when the module wakeup from PSM mode ,the network will remember the registered status of this module.
