I set 4 minutes for T3412 timer and 2 minutes for T3324.
Everything works perfect but, a would like to set some kind of additional timer. For example if BG96 is not on PSM mode and if there is no AT command from uC, modem should go to PSM mode after 20 seconds.
If is this possible?
Is it the treshold parameter response for that kind of action AT+QPSMCFG ??
yes we can. but i think not AT+QPSMCFG command.
AT+QNWCFG=“activetimer” command can set a timer when no AT command from UART, the modem will be enter PSM instend of waiting T3324 expired.
Please help check this command if support on your device fw version.
And also, AT+QCFG=“psm/enter” command maybe help you as well, for more details please check AN document.
AT+QCFG=“psm/enter” commond can let UE enter PSM immediately once RRC released. the time
from CONNECT to IDLE(RRC release) depend on NWS(network station), about 10-20s i think.
