Hello, i try to connect the bg96 with mqtt protocol to a server. I open successfully the server and when i try to connect, the output is +qmtstat 0,1 which means that server disconnect. I repeat the same procedure and has the same results. username password are ok.
hi,Katsikas:
I recommend you use MQtt.fx for debugging, most likely due to CA certificate issues
mqttfx-1.7.1-windows-x64.exe
Hi guys,
I have exactly the same problem, do you resolve it ?
Can you explain me how to handle this problem ?
Can you provide the complete AT log?
