we have used a BG96 based Mini PCIe module from a different vendor in out system, and during 8KV ESD discharge tests near the antenna the BG96 module has failed after which it was unable to connect to a network anymore.
I wanted to know if the BG96 Mini PCIe made by quectel has the same issue, or if there is any ESD protection on the antenna line.
thank you
