I also have a need to connect the BG96 to a Host MCU with no luck. To test this independently I’m connecting the uart1 to the PC directly via., a TTL to USB adaptor (3.3 V). However the module still dont respond. I have seen done garbage printed
Where as there is no issue with the USB-AT cmd port. Only the UART1 is having issue.
I have set the baud rate to 115200
How to troubleshoot this further ? The TTL to USB adaptor is working with the UART3 (GPS). Onl the UART1 (AT cmd Port) is having issue
Hello, I would like to ask for technical help regarding the BG96 MODULE, after several tries, I am unable to connect through the main UART, I have checked that all signals are correct, and the start-up sequence is indeed correct with PWK being set and 1.8 V being generated but I never got the APP ready message.
A similar setup using the BG96-TE-A in a custom board with the same external circuit works without problem. Could you aid if possible?
Stat and net lights are working in running mode, 1.8V is working without problem and a TXS0108EPWR is used as a level converter but only TX and RX are being used, could any flow control signal cause this behaviour
