I’m trying to register a Quectel BG96 (FW BG96MAR03A10M1G) to the public Eclipse Leshan test server in no-security mode.
The module is on SK Telecom Cat-M1. The default PDP context comes up fine with an automatically assigned APN (AT+CGDCONT=1,“IPV4V6”,“”)
When I start the LwM2M client, the URC stream stops at STATE_REGISTERING—no error codes, no further state changes. I’m not sure what’s failing or whether I’ve missed a required step. Am I doing something wrong, or is there a known quirk that could explain this stall?
Environment
| Item | Value |
| Module / FW | BG96 MAR03A10M1G |
| Network | SKT LTE-M1 (APN auto-assigned, IPv6 address Only) |
| Server | coap://leshan.eclipse.org:5683 |
| Security | 3 = No-Security |
| Bootstrap mode | 0 = Factory Bootstrap (disabled) |
Sent Command
AT+QIACT=1
AT+QLWM2M="enable",0
AT+QLWM2M="clean"
AT+QLWM2M="select",0
AT+QLWM2M="cdp","coap://leshan.eclipse.org",5683
AT+QLWM2M="bsmode",0
AT+QLWM2M="bootstrap",4,3
AT+QLWM2M="endpoint",4,4
AT+QLWM2M="apn",""
AT+QLWM2M="enable",1
AT+QLWM2M="register",1
Then I received the following URC log
+QLWEVENT: 0,"STATE_INITIAL"
+QLWEVENT: 3,"STATE_REGISTER_REQUIRED"
+QLWEVENT: 4,"STATE_REGISTERING"
[stucks here]
