BG96 latest firmware
My BG96 is reporting version BG96MAR02A07M1G_01.017.01.017
What is the latest stable version I should be using ?
Hi @jonreid
Please find the attachment:
Thank you for this.
I am using a RAK5010 module and I have realised it does not have USB access to the BG96. Where could I get a FOTA file from ?
Hi @jonreid
Please send AT+QGMR version here and FOTA file will generate according your current firmware. probably it will take couple of days, is ok for you?
My version is BG96MAR02A07M1G_01.017.01.017
couple of days is fine. Thank you
Hi @jonreid
BTW, is ok for you about cannot downgrade from latest to 01.017 version?
Actually I have just found out that the RAK5010 has now been updated to use the BG95-M3 so I wont need this FW now. Thanks
I have also this module with this version of Firmware BG96MAR02A07M1G_01.017.01.017 I am looking for the new version.
Any issue in your side? Much appreciation
Hi, I received the new firmware but still have an issue. When I try to send an SMS after another SMS, most of the time I encounter the CSM 500 Error. I even tried adding a 10-second delay after each SMS, but it didn’t help.
