We have a problem with BG96 Module (FW: BG96MAR02A07M1G):
When we try to send a file by AT+QHTTPPOSTFILE, if the filesize is greather than 2047 bytes, the modem goes in loop state and continues to send the same until the timeout reaces.
Using AT+QHTTPOST via UART, the transmission of the same file goes well.
Anyone have found a workaround without firmware upgrade?
Hi Stephen, yes error code 702: HTTP Timeout.
I’ve tried different network, TIM (22201), Vodafone (22210) and Wind (22288), same problem with all of them.
Sent an email to support as you suggested.
