I have a question regarding POST requests on the BG96 using the AT+QHTTPPOST command.
The server I want to post to is behind a proxy, so a redirect (HTTP 302) is returned from the server first.
When I do a GET request (AT+QHTTPGET) to that url, the BG96 seems to handle this, as I correctly receive the expected data from the server and a HTTP response code 200.
However, when I do a POST request to the same url, the BG96 returns a HTTP response code 302 and I don’t see any POST data on the server.
Is this expected behavior for the AT+QHTTPPOST command, or should its behavior be equal to the AT+QHTTPGET command? Or is there any setting I can change to automatically follow the redirect?
Thank you in advance.
Kind regards,
Klaas
