Just a heads up, the reply to AT+QGPSLOC is diferent than the example on the app note (v 1.1).
Here’s the example:
The actual reply:
You can see the N and W parameters in the reply are actually separated from the coordinates by a comma ‘,’.
Also the command in the example seems to be using the ? parameter, which isn’t documented.
Regards
