Hi everyone,
I have a problem with BG96 configuration (FW version: BG96MAR02A07M1G). I need to disable GSM RX and TX (at least temporary), but leave GNSS location getting possibility. I tried to use ‘AT+CFUN=4’ and after that enable GNSS with ‘AT+QGPS=30,50,0,1’, but then no valid position getting occurs. Is possible to turn off GSM and still use GNSS?
Best regards
Aleksander
for BG96 module , There is no ralationship between GSM and GNSS , you can do it .
pls do not change the parameter of “AT+QGPS:” , and use the default value as below
AT+QPRTPARA=3 //restoreing factory setting .
//waiting2mins
2 . AT+QGPSCFG=“outport” //qurery the output port -
AT+QGPSCFG=“outport”,“uartnmea” //set the output port
AT+QGPS=1 //enbale GNSS
