BG96 firmware upgrade under Linux
Hello, we have miniPCIe BG96 with two different firmware revision:-
  • BG96MAR02A07M1G_01.102.01.102
  • BG96MAR02A10M1G_01.014.01.014
We do not sure which one is the latest firmware? Could you please advise should we upgrade/downgrade to the same revision? Can I have firmware packages for both of these revision and/or is there newer revision? It’d be better if you can provide the firmware upgrade tool under Linux. Thank you.
My email address is gurucafe@gmail.com
It is possible to upgrade to the same version. The new firmware version and upgrade tool have been sent to you by email.
I got it, thanks! I will try to upgrade.
