BG96 Firmware update MAR 23
I have a BG96 with Version: BG96MAR02A07M1G.
Could you please provide me with the latest firmware version as well as the software tool for the update.
Philip
Hi
I can’t see your email, can you send your email to me? I will send it to you by email.
Latest upgrade Tool QFLASH_v6.2
And here is latest FW but to be note: This Firmware cannot downgrade !!! if you need to do some downgrade please use another one.
Hi, Thanks for your support. I have upgraded the module now to 01.102.01.102.
For final certification, we perform test of BG96 with R&S CMW290 base station simulator.
The BG96 has inserted the SIM card for the tester. Connection from BG96 to tester CMW290 is established at Band 3 with LET Cat M1 and the tester starts upload. Data is transferred for 30 seconds with 20dBm, then power sinks to -11dBm and connection closes.In the log, the message “UL sync error” is present.
After a couple of seconds it registers and connect again, then the same again.
Any ideas why the test stopps?
Are there special configuration required to do this test? Or have I miss configured the BG96?
I have make shure that PSM and eDRX is off.
Hello Support,
When I try to download QFlash_V6.2_EN.zip with the link you provided, the download appears to complete, but there is message in my download bar with a status indicating “Failed - Forbidden”.
Do I need some additional access rights beyond being logged into my Quectel and Forum accounts?
Thank you!
Ryan
Hi @rsherrymsa
I think there is no need aditiional rights, please try with follow link again:
Thank you @Linkin-Q !
I have a BG96 with Version: BG96MAR02A07M1G_01.200.01.200.
Could you please provide me with the spec (firmware release notes), we want to know the update information about the differences from other vers. We want to know whether we can use this ver in Japan.
If it is difficult, could you please let us know what is the update from ver. BG96MAR02A10M1G_01.102.01.102 ?
Can we use the FW:[BG96MAR02A10M1G_01.102.01.102.zip] for Version: [BG96MAR02A07M1G_01.200.01.200] ?
Hi @rengun_tou
The version 01.200.01.200 cannot update to 01.102.01.102, for Japan, which carrier certification needed?
We need to update the firmware of our BG96 to the latest firmware. Its current version is BG96MAR03A06M1G_01.005.01.005.
Could you provide us with a download link with the latest version?
Hi Can you please share the BG-96 newest firmware with me as well. I am on BG96MAR02A07M1G_01.014.01.014. I am using it in Australia
