We are using our BG96 (running BG96MAR02A07M1G_01.019.01.019) to publish and receive MQTTS messages to AWS IoT Core as well as upload files to S3 via HTTPS.
We have found that following an initial period of successful connection and sending msgs, if there is a period of inactivity of about 100 seconds, we fail to publish any more msgs or use https without rebooting the device.
I was unable to identify any key timeout parameters that would be the cause of this, or make sense of the ERROR return values. Is there something I have missed in the setup?
Here is the serial output of the BG96 during such a session. I have removed a few things (urls, device id’s, certificates)
AT
AT
AT
AT
AT
AT
AT
AT
AT
AT
AT
AT
RDY
AT
AT+CFUN=1,1
AT+CFUN=1,1
RDY
APP RDYAT
AT
ATE0
ATE0
AT+CMEE=0
AT+CTZR=0
AT+CTZU=1
AT+CPIN?
+CPIN: READY
AT+QGMR
AT+CEREG?
+CEREG: 0,5
AT+QIDEACT=1
AT+QICSGP=1,1,"hologram","","",1
AT+QIACT=1
AT+CGATT=1
AT+QLTS=1
+QLTS: "2022/10/04,23:00:11+44,1"
AT+QMTOPEN?
AT+QMTCFG="SSL",0,1,1
AT+QMTCFG="keepalive",0,3600
AT+QSSLCFG="sslversion",1,4
AT+QSSLCFG="ciphersuite",1,0xffff
AT+QSSLCFG="seclevel",1,2
AT+QSSLCFG="ignorelocaltime",1
+QSSLCFG: "ignorelocaltime",1,1
AT+QSSLCFG="cacert",1,"iot_root.pem"
AT+QSSLCFG="clientcert",1,"iot_cert.pem"
AT+QSSLCFG="clientkey",1,"iot_key.pem"
AT+QMTOPEN=0,"",8883
+QMTOPEN: 0,0
AT+QMTCONN=0,""
+QMTCONN: 0,0,0
AT+QMTSUB=0,1,"$aws/things//shadow/delta",1
+QMTSUB: 0,1,0,1
AT+QMTSUB=0,1,"$aws/things//shadow/get/rejected",1
+QMTSUB: 0,1,0,1
AT+QMTPUB=0,1,1,0,"$aws/things//shadow/get",2
+QMTPUB: 0,1,0
+QMTRECV: 0,1,"$aws/things//shadow/delta","{"fw": false, "imu": [0]}"
AT+QMTPUB=0,1,1,0,"$aws/things//shadow/update",81
>{"state":{"reported":{"fw":"3.0.22","iccid":"","imu":[0,0]}}}
+QMTPUB: 0,1,0
AT+QCSQ
+QCSQ: "CAT-M1",-67,-97,145,-12
AT+QMTPUB=0,1,1,0,"node/telemetry/",216
>{"signal":{"rssi":-67,"rsrp":-97,"sinr":145,"rsrq":-12},"BattV":3945,"pressure":99183,"temp":18,"co2_b":637,"temp_b":22.69180298,"humid_b":39.5324707,"meth_b":-1498,"imu":[[0,0],[0,0],[0,0]],"onboardTime":1664924531}
AT+QMTPUB=0,1,1,0,"node/alert/",82
ERROR
AT+QMTPUB=0,1,1,0,"node/alert/",102
ERROR
AT+QSSLSTATE=0
AT+QSSLCLOSE=0
AT+QSSLCFG="sslversion",2,4
AT+QSSLCFG="ciphersuite",2,0xffff
AT+QSSLCFG="seclevel",2,1
AT+QFDEL="api_root.pem"
AT+QFUPL="api_root.pem",1468,100
+QFUPL: 1468,6c33
AT+QSSLCFG="cacert",2,"api_root.pem"
AT+QSSLCFG="negotiatetime",2,300
AT+QSSLCFG="ignorelocaltime",2,0
AT+QSSLOPEN=1,2,0,"",443,1
+QMTPUB: 0,1,2
AT+QMTPUB=0,1,1,0,"node/alert/",79
>{"alert":"connectS3CatM1() - Failed to connect to S3","onboardTime":1664924580}
AT+QPOWD=1
+QIURC: "pdpdeact",1
+QMTSTAT: 0,1
