When I try to establish a connection between my BG96 and a certain server, I get DNS parsing error messages, which includes HTTP, MQTT, TCP and UDP protocols.
I managed to establish connection and send data once with UDP protocol, but then I used IPv4 address instead of URL. However I could NOT establish a connection with the other protocols (MQTT, HTTP and TCP) using IPv4.
I checked:
The NB-IoT network and SIM, everything seems good.
The domain name of the server is valid.
Protocols configurated with their respective AT commands. (eg. AT+QMTCFG)
PS domain attached and registered.
PDP context is activated.
DNS server is properly set. I even tried to change the default to something, still no luck.
Any idea where might the problem be?
Thank you.
