Hi there,
I see both commands used in the Quectel forum, but it is not documented in the AT command manual.
What is the difference between at+qprtpara=3 and at+qcfg=“nvrestore”,0 ?
Which command is better to use if I want to reset a BG96 to it’s default state? For the record, I’m not using it in production firmware, I only need a command to reset the module to it’s absolute default state after I have performed AT command experiments (during R&D).
Thanks in advance,
Pieter
https://piconomix.com
