I’d like to upgrade the firmware of our BG96 modules to enable the AT+QSSLCFG=“sni” command.
It seems like this command is not supported on our modules with firmware versions:
BG96MAR02A07M1G_01.007.01.007
BG96MAR03A06M1G_01.005.01.005
Can you provide DFOTA firmware upgrade packages for both of these firmware versions? Latest firmware would be great, but we are happy with any firmware upgrade which supports the SNI AT command.
Thank you for your reply. Unfortunately we don’t have physical access to the devices. They are all in use in the field. So, I think QFlash or QMultiDL isn’t an option.
We’ve had different distributors, the last modems came from Mouser and Distrelec.
Our company name is Strukton.
We have 90+ BG96 in use at this moment (some of them already have a suitable firmware version).
First please check whether it support the feature you need.
If it support and you need the DFOTA firmware, please send me an email bean.wang@quectel.com. I will try to apply for it. If I cannot provide it please check with the local FAEs.
