Hi !
I have an issue related to my Quectel BG96 Module.
For my application, I need to use the command AT+QICFG="recvind",1
in order to add a parameter at the end of an UDP unsolicited response.
This command isn’t implemented on the firmware of my module. According to the documents I found, it was added in revision 01.008.01.008
; sadly my module is under the revision 01.007.01.007
This is why I need to make a firmware update. I’ve turned to FOTA (Delta FOTA here in fact).
I’ve followed the instructions given in BG96 DFOTA User Guide (found here : http://www.dragino.com/downloads/downloads/NB-IoT/BG96/Quectel_BG96_DFOTA_User_Guide_V1.0.pdf) ; I’ve only found this .bin file as a delta firmware file between 01.007.01.007
and 01.008.01.008
(tutorial & file here : https://forum.rakwireless.com/t/how-to-upgrade-the-firmware-of-bg96-on-itracker-module/37/2).
I’ve uploaded to a AWS S3 Bucket ; and tried to download it & update it. Below is a log of what happened but I basically got a +QIND: "FOTA","HTTPEND",702␍␊
after 6 minutes.
Can you help me achieve the firmware update by any mean ? Is the file that I got a valid one (even thought it’s a .bin one instead of a .zip one) ? Do you have any idea of a similar command that I would’ve missed available in 01.007.01.007
Thanks a lot for your help,
Thomas
Here’s the log :
[16:17:37:700] AT+QGMR␍␍␊
[16:17:37:700] BG96MAR02A07M1G_01.007.01.007␍␊
[16:17:37:700] ␍␊
[16:17:37:700] OK␍␊
[16:18:13:645] AT+CGDCONT?␍␍␊
[16:18:13:645] +CGDCONT: 1,"IP","iotinternet","0.0.0.0",0,0,0,0␍␊
[16:18:13:656] ␍␊
[16:18:13:656] OK␍␊
[16:18:18:906] AT+CSQ?␍␍␊
[16:18:18:906] +CME ERROR: 3␍␊
[16:18:24:042] AT+CSQ␍␍␊
[16:18:24:042] +CSQ: 16,99␍␊
[16:18:24:042] ␍␊
[16:18:24:042] OK␍␊
[16:18:29:102] AT+COPS?␍␍␊
[16:18:29:102] +COPS: 0,0,"F SFR",0␍␊
[16:18:29:102] ␍␊
[16:18:29:102] OK␍␊
[16:18:34:984] AT+CREG?␍␍␊
[16:18:34:984] +CREG: 0,1␍␊
[16:18:34:984] ␍␊
[16:18:34:984] OK␍␊
[16:18:43:529] AT+CGREG?␍␍␊
[16:18:43:529] +CGREG: 0,1␍␊
[16:18:43:529] ␍␊
[16:18:43:529] OK␍␊
[16:19:02:198] AT+QFOTADL="https://http-dfota-test.s3.eu-west-3.amazonaws.com/dfota07-08.bin"␍␍␊
[16:19:02:255] OK␍␊
[16:19:02:255] ␍␊
[16:19:02:255] +QIND: "FOTA","HTTPSTART"␍␊
[16:26:03:051] ␍␊
[16:26:03:051] +QIND: "FOTA","HTTPEND",702␍␊
