[BG96] CME ERROR 13 for AT+QCCID and CME ERROR 3 for AT+CIMI
Hi team,
I am using kit Dragino NB-IoT shield, connect to Arduino Uno, to send AT command to BG96.
At first time, there is nothing was wrong, I still successfully checked the IMEI, CCID of the USIM, but everything seems going to be wrong when I decided to send “AT+QSIMDET=1,0”. I can’t check the IMEI or CCID of USIM any more. Please help me.
I have attached all of my process below.
Thanks a lot for reading,
Best regards,
Xuan Thanh.
// I intend to know whether the SIM is inserted /connected to the BG96 with some AT commands.
// My very first initial state when nothing was wrong before I decided to send “AT+QSIMDET=1,0”.
AT+QINISTAT
+QINISTAT: 3
AT+QINISTAT=?
+QINISTAT: (0-3)
AT+QSIMSTAT=?
+QSIMSTAT: (0,1)
AT+QSIMSTAT?
+QSIMSTAT: 0,1
// Seems still has no problem now.
AT+QSIMDET?
+QSIMDET: 0,0
*** Van de xuat hien sau lenh "AT+QSIMDET=1,0
//enable detection USIM
AT+QSIMDET=1,0
// Kiem tra lai coi co kich hoat chua
// check if it is enabled or not
AT+QSIMDET?
+QSIMDET: 1,0
AT+QSIMDET=?
+QSIMDET: (0,1),(0,1)
AT+QSIMSTAT=?
+QSIMSTAT: (0,1)
AT+QSIMSTAT?
+QSIMSTAT: 0,0
AT+QSIMSTAT=1
// Tu doan nay minh thao sim va gan lai sim
// At that time, I began to remove and insert (u)sim repecstively.
AT+QSIMSTAT?
+QSIMSTAT: 1,0
AT+QSIMSTAT?
+QSIMSTAT: 1,0
AT+QSIMSTAT?
+QSIMSTAT: 1,0
AT+QSIMSTAT?
+QSIMSTAT: 1,0
AT+QSIMSTAT?
+QSIMSTAT: 1,0
AT+QSIMSTAT?
+QSIMSTAT: 1,0
AT+QSIMSTAT?
+QSIMSTAT: 1,0
*** thay co gi do khong on nen kiem tra cac thong so khac
*** I felt something was wrong so I checked other parameters.
AT+QINISTAT=?
+QINISTAT: (0-3)
AT+QSIMDET=?
ATE
ATI
BG96
Revision: BG96MAR02A07M1G
AT+CGSN=?
AT+CGSN
868446031757533
AT+QINISTAT=?
+QINISTAT: (0-3)
AT+QSIMSTAT?
+QSIMSTAT: 1,0
AT+QSIMSTAT?
+QSIMSTAT: 1,0
AT+QSIMSTAT?
+QSIMSTAT: 1,0
AT+QSIMSTAT=?
+QSIMSTAT: (0,1)
*** Problem No.1, QINISTAT RETURNS VALUE “0”, not “3” like above.
07:35:33.116 → AT+QINISTAT
07:35:33.116 → +QINISTAT: 0
07:35:33.151 →
07:35:33.151 → OK
07:36:26.884 → AT+QINISTAT=?
07:36:26.918 → +QINISTAT: (0-3)
07:36:26.918 →
07:36:26.918 → OK
07:37:12.527 → AT+QSIMDET=?
07:37:12.561 → +QSIMDET: (0,1),(0,1)
07:37:12.561 →
07:37:12.561 → OK
07:37:32.569 → AT+QSIMDET?
07:37:32.569 → +QSIMDET: 1,0
07:37:32.569 →
07:37:32.604 → OK
07:37:52.863 → AT+QSIMDET=1,1
07:37:52.932 → OK
07:38:00.784 → AT+QINISTAT
07:38:00.818 → +QINISTAT: 0
07:38:00.818 →
07:38:00.818 → OK
07:38:53.715 → AT+QINISTAT?
07:38:53.749 → ERROR
07:39:01.607 → AT+QSIMSTAT?
07:39:01.607 → +QSIMSTAT: 1,0
07:39:01.642 →
07:39:01.642 → OK
07:39:35.455 → AT+QSIMSTAT?
07:39:35.455 → +QSIMSTAT: 1,0
07:39:35.490 →
07:39:35.490 → OK
07:40:21.768 → AT+QINISTAT
07:40:21.768 → +QINISTAT: 0
07:40:21.802 →
07:40:21.802 → OK
07:45:06.352 → AT+QSIMDET=1,0
07:45:06.420 → OK
07:45:26.316 → AT+QINISTAT
07:45:26.316 → +QINISTAT: 0
07:45:26.316 →
07:45:26.316 → OK
07:45:29.850 →
*** Panic time
// I hit button reset
07:45:36.343 → RDY
07:45:36.410 →
07:45:36.444 → APP RDY
// checked again
07:45:45.722 → ATE
07:45:45.757 → OK
07:45:48.068 → ATI
07:45:48.102 → Quectel
07:45:48.102 → BG96
07:45:48.102 → Revision: BG96MAR02A07M1G
07:45:48.137 →
07:45:48.137 → OK
07:46:43.530 → AT+IPR?
07:46:43.530 → +IPR: 9600
07:46:43.530 →
07:46:43.530 → OK
07:47:24.646 → AT+QINISTAT=?
07:47:24.646 → +QINISTAT: (0-3)
07:47:24.681 →
07:47:24.681 → OK
07:47:31.564 → AT+QINISTAT
07:47:31.564 → +QINISTAT: 0
07:47:31.564 →
07:47:31.564 → OK
07:48:43.116 → AT+QSIMSTAT?
07:48:43.116 → +QSIMSTAT: 1,0
07:48:43.150 →
07:48:43.150 → OK
07:48:58.613 → AT+QSIMDET?
07:48:58.647 → +QSIMDET: 1,0
07:48:58.647 →
07:48:58.647 → OK
07:57:01.003 → AT+CLCK=?
07:57:01.003 → +CLCK: (“AB”,“AC”,“AG”,“AI”,“AO”,“IR”,“OI”,“OX”,“SC”,“FD”,“PN”,“PU”,“PP”,“PC”,“PF”)
07:57:01.105 →
07:57:01.105 → OK
/// After a while, i decided to upload code from Arduino then run again,
then another problem revealed.
11:04:34.564 → wellcom to dragino
11:04:41.818 → ATE
11:04:41.818 → OK
11:04:46.025 → ATI
11:04:46.025 → Quectel
11:04:46.025 → BG96
11:04:46.025 → Revision: BG96MAR02A07M1G
11:04:46.059 →
11:04:46.059 → OK
11:05:09.105 → AT+QCCID
11:05:09.105 → +CME ERROR: 13
11:05:17.072 → AT+QCCID
11:05:17.106 → +CME ERROR: 13
11:06:22.394 → AT+CGSN
11:06:22.428 → 868446031757533
11:06:22.428 →
11:06:22.428 → OK
11:06:40.597 → AT+CIMI
11:06:40.597 → +CME ERROR: 3
11:07:02.479 → AT+QCCID
11:07:02.514 → +CME ERROR: 13
11:07:17.048 →
11:07:24.792 → RDY
11:07:24.860 →
11:07:24.860 → APP RDY
11:07:35.328 → ATE
11:07:35.362 → OK
11:07:37.830 → ATI
11:07:37.865 → Quectel
11:07:37.865 → BG96
11:07:37.865 → Revision: BG96MAR02A07M1G
11:07:37.899 →
11:07:37.899 → OK
11:07:44.565 → AT+QCCID
11:07:44.600 → +CME ERROR: 13
// I stoped doing more stupid things at this time.
based on your AT log ,
pls check your sim slot , it is hw issue ,
Hardware problems caused by repeatedly plugging in and out SIM card
the sim card is at removed . status
