BG96 AT+QHTTPPOST error 730 invalid parameter
Hello
GET method is ok
But POST already in error when i use AT+QHTTPPOST (error 730)
Have you got an idea?
Regards.
TX → ATI
BG96
Revision: BG96MAR02A07M1G
TX → AT+QGMR
BG96MAR02A07M1G_01.007.01.007
TX → AT+QHTTPCFG=“contextid”,1
TX → AT+QHTTPCFG=“contenttype”,1
TX → AT+QIACT?
TX → AT+QICSGP=1,1,“sl2sfr”,“”,“”,1
TX → AT+QIACT=1
TX → AT+QIACT?
+QIACT: 1,1,1,“100.69.67.62”
TX → AT+QHTTPCFG=“sslctxid”,1
TX → AT+QSSLCFG=“sslversion”,1,1
TX → AT+QSSLCFG=“ciphersuite”,1,0x0005
TX → AT+QSSLCFG=“seclevel”,1,2
TX → AT+QSSLCFG=“cacert”,1, “cacert.pem”
TX → AT+QSSLCFG=“clientcert”,1, “clientcert.pem”
TX → AT+QSSLCFG=“clientkey”,1, “clientkey.pem”
TX → AT+QHTTPCFG?
+QHTTPCFG: “contextid”,1
+QHTTPCFG: “requestheader”,0
+QHTTPCFG: “responseheader”,0
+QHTTPCFG: “sslctxid”,1
+QHTTPCFG: “contenttype”,1
TX → AT+QHTTPURL=33,80
CONNECT
TX → AT+QHTTPPOST=22,80,80
+CME ERROR: 730
Dear Customer,
Pelase add path ahead of the certificate file.
e.g.:
AT+QSSLCFG=“cacert”,1, “ufs:cacert.pem”
Hello, thanks for your reply, but same error.
Did you also add path for “clientcert” and “clientkey”?
Same Error ..
Did you upload the certificate files to module? Please refe to FILE_AT command manual to uplaod the certificate file.
No, sorry, but
i don’t understand what i have to do
i follow the exemple : Send HTTPS POST Request and Read the Response, in Quectel_BG96_HTTP(S)_AT_Commands_Manual_V1.0.pdf, and it doesn’t work
You need to get the certificate files form server first, then use AT+QFUPL command to upload the certificates.
You could search AWS IOT website and create an account. Then you can create and manager your devices on the AWS server.
i resolve my problem with
AT+QSSLCFG=“sslversion”,1,4
AT+QSSLCFG=“ciphersuite”,1,0xFFFF
AT+QSSLCFG=“seclevel”,1,0
AT+QSSLCFG=“cacert”,1,“ufs:cacert.pem”
AT+QSSLCFG=“clientcert”,1,“ufs:clientcert.pem”
AT+QSSLCFG=“clientkey”,1,“ufs:clientkey.pem”
Now i have to post a message , i try with POSTMAN with & without requestheader, and it work.
I try without request header with my BG96, it’s work,
But with request header i have a 400 error.
the header is basic
//The HTML Header
const char cc_header01 = “Content-Type: application/json\r\n”;//32 chars
//Signifies end of Header
const char cc_header02 = “\r\n”;//2 chars
so → 34 characters
my message : const char cc_PostMessage = “{ "echo" : "bidul" }”;
so = { echo : bidul } → 20 characters
My QHTTPOST is AT+QHTTPPOST=54,80,80
but doesn’t work.
Regards.
Tha’s expected. In non-request header mode, modem will encapsulate and send the HTTP header automatically, while in request header mdoe, user should add the HTTP header in the post contents.
For example:
AT+QHTTPPOST=170,80
PUT /Willie/QuectelTest.txt HTTP/1.1
Host: 220.180.239.212:8005
Content-Type: text/plain
Accept: /
Content-Length: 43
This text is XXXX HTTP test by using CAT-M.
I see the same 730 error on an EC21 when trying to to QHTTPPOST to a HTTPS URL. We’re using non-request mode, and get the error as soon as we run the AT+QHTTPPOST command even without givign the body.
Obviously missing a step somewhere, but not sure what??
Hi Sir,
In EC21A, pelase remove the prefix “ufs:” for the certificates path…
HI I am also facing the same issue +CME ERROR:730 for HTTPPOST command. what step is missing in this sequence
@WillieYao-Q @shughes @guillaume
Regards
Sivanantham A
