I’m working with a BG96 dev board and I’m conecting it through UART to an MCU.
Actually I’m trying to connect to internet and as far as I know I have to create a PDP context.
The command of the topic (AT+CGDCONT?) is supposed to print all the PDP context available/defined but what is the command to delete a PDP context? or once defined you can only modify it?
In case it’s only possible to modify it, what would be the parameters for a “useless” PDP context?
I was not able to find the command on the BG96 AT command manual.
Thanks.
AT+CGDCONT= can be used to delete a PDP context. Actually, if you don’t activate the PDP context, it will effect nothing.
How do you delete the context using AT+CGDCONT= ?
I’m not being able to do it.
I have another doubt:
AT+CGDCONT? should answer with a String like this:
+CGDCONT: <cid>,<PDP_type>,<APN>,<PDP_addr>,<data_comp>,<head_comp>
But when I use the command I received:
+CGDCONT: 1,“IP”,“APN”,“0.0.0.0”,0,0,0,0
in which:
- <cid> = 1
- <PDP_type> = “IP”
- <APN> = “APN”
- <PDP_addr> = “0.0.0.0”
- <data_comp> = 0
- <head_comp> = 0
but still I receive ,0,0 after all, what does those last parameters mean?
I checked the command in 3GPp document. The last two command is ...
Here is the description for this parameter:
, … : zero to N string parameters whose meanings are specific to the <PDP_type>
But I didn’t understand the description… Generally, we just need to consider the first three paramters.
I had a typo in that reply. It sould be AT+CGDCONT=[cid] to delete context profile. e.g.: AT+CGDCONT=1
