Hi there and Happy New Year!
I have a BG96 Revision: BG96MAR02A07M1G.
I’m trying to make the AGPS working. It is possible for this firmware?
There is a workable example?
All the best
All the best
Quectel_BG96_GNSS_AGPS_AT_Commands_Manual_V1.0_Preliminary_20180514.pdf (558.6 KB) Quectel_BG96_GNSS_AT_Commands_Manual_V1.1.pdf (388.3 KB)
for BG96 AGPS function, pls refer to the docs attached
Hello Stephen,
Thank you for that material! I knew it, but there were some problems.
I had some delay on the production timeline, but we have to deliver after all :).
In the manual there is:
AT+QGPSCFG=“plane”,0 //Set AGPS user plane mode without SSL
AT+QGPSSUPLURL=“supl.google.com:7276” //Set SUPL server URL
AT+QGPSCFG=“lbsapn”,16,1,“vzwinternet” //Set LBS APN
AT+QGPS=2 //Start AGPS MSB mode
My problem is that the provider is Vodafone, with user & pass. How to set up “LBS APN”
I’ve tried several things, but with no luck.
With gpsOneXTRA, I’ve seen some improvement. It would be great to see AGPS, too for comparison.
All the best,
Viorel
