Bg95m3 - bg600l wwan and gnss service problem
Here’s the English translation:
"After establishing an MQTT connection with the BG95 module, when I activate GNSS, the MQTT connection drops. Why does this happen? Is there a way to fix this for BG95M3 and BG600L models? If I reprogram the module using OpenQuectel SDK or QuecPython, can I use both services simultaneously?
My goal is to receive data from GNSS and send it via MQTT, but how can both services run simultaneously?
May I ask if you are currently using Quecpython? Quecpython supports both GNSS and MQTT
Yes, Quecpython firmware is loaded on the module, but when I start GNSS (quecgnss.init()), the connected socket connection drops.
hi,berk
I’m sorry. I confirmed with the internal team that BG95M3 shares the RF receiver of LTE and GNSS on the hardware, so it cannot work at the same time.
Please try using quecgnss.setPriority(Priority) to configure the priority of LTE and GNSS
0 GNSS>LTE
1 LTE>GNSS
Thank you for your research Felix . Can the MC60 product be used at the same time both wwan and gnss?
hi, Berk
Sorry for the late reply.
May I ask which specific model the MC60 is? I need to confirm first whether it supports Quecpython
In addition, I have also confirmed that the BG600L does not support the simultaneous use of GNSS and LTE either
No problem Felix, thank you for your research. All functions work on the model I have. I just need an up-to-date reference design. Can you share it as a pdf?
May I ask which module model’s reference design you need?
Generally speaking, you can download our documents through the following link.
Resources Download | QuecPython
