We are using bg95a-gl module in our of our product development.
Here is the information of our module from ATI command:
ATI
BG951A-GL
Revision: BG951AGLAAR01A03
Can we get a latest firmware package for this module to upgrade through QFlash?
Thanks,
Parth
QFlash is available. You can use ATI to query the following version details. And send your email as well.
Thank you for your response.
This is the firmware version details I got from modem from the suggested command:
AT+QGMR
BG951AGLAAR01A03_01.001.01.001
My email address is parthraj.gohil@oxit.com
Can you share the latest firmware so that I can perform an upgrade?
Thanks,
Parth
I have shared two firmware packages with you. 1.002 can be rolled back after upgrade, while 1.200 is not a version that can be rolled back. Please use it as required.
Thank you so much for sharing the firmware files.
I got below error when try to upgrade to BG951AGLAAR01A03_01.203.01.203.
Can someone help to address this issue?
Below is my error message, how to fix this? (Upgrade to BG951AGLAAR01A03_01.203.01.203)
FAIL, 72 / 72[5632] failed to execute script cxd5605_commtraceback
(most recent call last): file “cxd5605_comm.py”, line 2068, in
file “cxd5605_comm.py”, line 1051, in write_fw_bin_cl file
“cxd5605_comm.py”, line 1031, in _write_fw_bin
Hi
I’m using a BG955A-GL and I think the firmware version is a bit old.
AT+QGMR
BG955AGLAAR02A01_01.007.01.007
Would be possible to have the latest delta file firmware version for DFOTA?
Thanks,
Otavio
