BG951A: Update firmware via USB with QFlash fails
My current firmware is: BG951AGLAAR02A01_JP
When using QFlashV7.0 to update firmware via USB, I got below error:
FAIL, !!! time out (20.01sec) h> !!!timeout error: failed to write firmware. cancels the subsequent processing
Thats because didnt detected GNSS boot. have you pull GNSS BOOT to high?
Does it work for you?
BTW, My device firmware is: BG951AGLAAR02A01_JP_01.001.01.001
Where can I get the firmware release note?
In most case, we just need to update LTE firmware.
Is it possible to bypass updating GNSS?
In additional, if GNSS is damaged, there is no way to update LTE any more now. (Because the update tool will update GNSS first.)
No, I think it’s a bug. Could you confirm if USB update via Qflash for BG951A-GL should work or not? I tested 2 devices with BG951AGLAAR02A01_JP and BG951AGLAAR01A03, it does not work.
Not support because GNSS FW cannot update by USB.
Then does BG950A_GL support firmware update by USB? (Which does not has GNSS FW)
