Hi
I am trying to replace a BG96 with BG95 as they share the same foot print. The problem I am facing is when the board is powered, the BG95 STATUS pin is not going high. It intermittently goes high but stays low most of the time.
I tried giving a low signal on POWER KEY but still it did not work.
Regards
Sundar
The module maybe enter psm mode, you need to disable psm. please try to use AT+CPSMS=0 command.
If the module is not up, how do we send commands to the module? Is there any other way using hardware, we can do this?
Short-circuit the module USB_boot pin and vdd_EXT pin, enter the forced download mode, and upgrade the firmware.
I have a qflash tool. Is this tool to be used for flashing the firmware? Any version specific to qflash? if it is fine to use qflash.
Also, I need the firmware for the BG95 chip. From where will I git the firmware?
please contact our sales or send an email to support@quectel.com to apply.
