BG95 SSL Manual Statement: "the configurations will not be saved"
Hello I am trying to set up my MQTT client which uses a BG95 for MQTT with SSL. But I notice under the section which describes SSL configuration “AT+QSSLCFG=” at the very bottom it has a section called characteristics. Which looks like:
What does this mean? that each time the module boots it needs to be fed the SSL configuration again? The specific application note I am referring to is BG95&BG77&BG600L Series SSL Application Note Does anyone know if this SSL info needs to be re-entered upon boot?
yes, it means that , this parameter will not been save
in NV , it should be configured before you setup ssl +TCP connection。
