Is there a timeline for implementing qapi_QT_Real_Time_Clock_Get? Or, is there another function available to obtain the real time from the module that I’m not seeing?
Calling it currently returns QAPI_QT_ERR_API_NOT_SUPPORT.
Nevermind… I found the time example and the qapi_time_get() method that does return the current RTC.
Not sure why there’s an RTC example and a time example, but I’ve got a way to get the clock and that’s what I needed.
Hi @SeanMollet
Could you post your code I am working with BG96 and RTC and Timer without problems, maybe I can find some error in your code
best regards.
Hi seanmollet ,
pls use qapi_time_get() ,
There is a little bug with the API of qapi_QT_Real_Time_Clock_Get(), we will fix it in the newest fw version ,
thanks for your understanding
I’m getting some weird issues with the time from qapi_time_get()
Sometimes it seems to move very fast and it stops synchronizing with the time from LTE.
