BG95-MF PON REASON Codes
I am currently debugging my BG95-MF because upon startup it just runs for around 15 sec and then reboots in a wierd mode, where I cannot interact with it (device manager only shows “QUSB_BULK_SN:…”).
I went through the UART logs and noticed the PON REASON (“B - 456867 - PM: PON REASON: PM0=0x400008000000080:0x0”) on normal startup and it changes to (“B - 456749 - PM: PON REASON: PM0=0x400004000020080:0x0”) on the second startup.
Now my question: Where can I find out what these codes mean and / or how can I fix this reboot?
PS.: I also want to add that flashing with QFlash also doesnt work (I always get “FAIL, DL_Firehose error!”), but that might be a problem for another Post.
Hi @m_macher
Is possible send a screen shot about device manager? (QUSB_BULK_SN…)
Hey @Linkin-Q,
Thank you for your response, but I managed to fix this issue by quickly connecting with QPST Software Download and upload a Software-Backup I had. after that the Board acted as usual.
If this Bug occures again I will give an update here and provide you with the screenshot. :slight_smile:
Hi @m_macher
Thanks for you feedback :slight_smile:
Hey @Linkin-Q ,
I’ve got a new module and the problem came up again, just that this time it goes into this “unknown driver”-mode almost instantly. So there is no time for me to connect with QPST.
Since I suspected that it had something to do with the driver, I tried designating one to the unknown device, (right-click on the device → update driver → choose driver from PC → choose driver from list → Quectel QDLoader Port). This triggered a communication with the chip (Some Sahara “pkt sent” and “Response Recieved” but it quickly leads to a reboot of the chip. It again shows the DM Port and NMEA Port for half a second, then reboots, sends some Sahara messages and reboots again.. this loops forever…
Logs without designated driver (“BULK…” in device manager):
Format: Log Type - Time(microsec) - Message - Optional Info
Log Type: B - Since Boot(Power On Reset),  D - Delta,  S - Statistic
S - QC_IMAGE_VERSION_STRING=BOOT.XF.0.2-00081-MDM9x05LZB-2
S - IMAGE_VARIANT_STRING=Mdm9x05LA
S - OEM_IMAGE_VERSION_STRING=HF-HYMAN
S - Boot Interface: SPI NAND
S - Secure Boot: Off
S - Boot Config @ 0x000a6070 = 0x00000041
S - JTAG ID @ 0x000a6130 = 0x001070e1
S - OEM ID @ 0x000a6138 = 0x00000000
S - Serial Number @ 0x000a6134 = 0x446d8f01
S - OEM Config Row 0 @ 0x000a41b0 = 0x0000000000000000
S - OEM Config Row 1 @ 0x000a41b8 = 0x0000000000000000
S - Feature Config Row 0 @ 0x000a41c8 = 0x0405050000000000
S - Feature Config Row 1 @ 0x000a41d0 = 0x0242f80400000609
S - Core 0 Frequency, 0 MHz
S - PBL Patch Ver: 4
S - I-cache: On
S - D-cache: On
B -       285 - PBL, Start
B -      4926 - bootable_media_detect_entry, Start
B -      5967 - bootable_media_detect_success, Start
B -      6289 - elf_loader_entry, Start
B -      7276 - auth_hash_seg_entry, Start
B -      8261 - auth_hash_seg_exit, Start
B -     36661 - elf_segs_hash_verify_entry, Start
B -     42252 - elf_segs_hash_verify_exit, Start
B -     42557 - auth_xbl_sec_hash_seg_entry, Start
B -     62642 - auth_xbl_sec_hash_seg_exit, Start
B -     62644 - xbl_sec_segs_hash_verify_entry, Start
B -     63983 - xbl_sec_segs_hash_verify_exit, Start
B -     64020 - PBL, End
B -     66750 - SBL1, Start (MPM timestamp = 77927)
B -    218708 - sbl1_ddr_set_default_params, Start
D -        27 - sbl1_ddr_set_default_params, Delta
B -    227181 - boot_config_data_table_init, Start
D -    212586 - boot_config_data_table_init, Delta - (0 Bytes)
B -    444322 - CDT Version:3,Platform ID:34,Major ID:1,Minor ID:0,Subtype:2
B -    448662 - pm_device_init, Start
B -    456835 - PM: PON REASON: PM0=0x400008000000080:0x0
B -    471459 - PM: SET_VAL:Skip
D -     17083 - pm_device_init, Delta
B -    473388 - pm_driver_init, Start
D -      2207 - pm_driver_init, Delta
B -    480072 - pm_sbl_chg_init, Start
D -       351 - pm_sbl_chg_init, Delta
B -    486843 - vsense_init, Start
D -         0 - vsense_init, Delta
B -    493581 - Pre_DDR_clock_init, Start
D -       306 - Pre_DDR_clock_init, Delta
D -         0 - sbl1_ddr_set_params, Delta
B -    505444 - do ddr sanity test, Start
D -         0 - do ddr sanity test, Delta
B -    511670 - pm_driver_init, Start
D -      2033 - pm_driver_init, Delta
B -    518788 - vsense_init, Start
B -    534456 - clock_init, Start
D -       102 - clock_init, Delta
B -    536390 - boot_flash_init, Start
D -      2476 - boot_flash_init, Delta
B -    543289 - Image Load, Start
D -      3013 - OEM_MISC Image Loaded, Delta - (0 Bytes)
B -    549816 - Image Load, Start
D -      4727 - APDP Image Loaded, Delta - (0 Bytes)
B -    558234 - PM: 0: PON=0x80:KPDPWR_N: ON=0x80:PON_SEQ: OFF=0x4:RAW_XVDD_SHD
B -    562335 - sbl1_efs_handle_cookies, Start
D -        11 - sbl1_efs_handle_cookies, Delta
B -    573696 - Image Load, Start
D -      3765 - QTI_MISC Image Loaded, Delta - (0 Bytes)
B -    580577 - Image Load, Start
D -      1766 - Auth Metadata
D -     10788 - QSEE Dev Config Image Loaded, Delta - (30208 Bytes)
B -    591802 - Image Load, Start
D -      5710 - SEC Image Loaded, Delta - (0 Bytes)
B -    600493 - pmic misc register imem initial value: 0
B -    605804 - Image Load, Start
D -      1457 - Auth Metadata
D -     19267 - RPM Image Loaded, Delta - (162540 Bytes)
B -    625587 - Image Load, Start
D -      3511 - STI Image Loaded, Delta - (0 Bytes)
B -    632043 - Image Load, Start
D -      4777 - Tiny Image Loaded, Delta - (0 Bytes)
B -    639683 - Image Load, Start
D -      1959 - Auth Metadata
D -    809590 - MPSS Image Loaded, Delta - (11675189 Bytes)
B -   1449304 - Image Load, Start
D -      1765 - Auth Metadata
D -    251724 - APPS Image Loaded, Delta - (3622788 Bytes)
B -   1701054 - Image Load, Start
D -     22327 - Auth Metadata
D -     89802 - QSEE Image Loaded, Delta - (835500 Bytes)
B -   1791184 - SBL1, End
D -   1728122 - SBL1, Delta
S - Flash Throughput, 18000 KB/s  (16326545 Bytes,  897994 us)
S - DDR Frequency, 336 MHz
S - I-cache: On
S - D-cache: On
B -      5808 - bootable_media_detect_success, Start
B -      6130 - elf_loader_entry, Start
B -      7117 - auth_hash_seg_entry, Start
B -      8101 - auth_hash_seg_exit, Start
B -     36500 - elf_segs_hash_verify_entry, Start
B -     42094 - elf_segs_hash_verify_exit, Start
B -     42400 - auth_xbl_sec_hash_seg_entry, Start
B -     62485 - auth_xbl_sec_hash_seg_exit, Start
B -     62486 - xbl_sec_segs_hash_verify_entry, Start
B -     63826 - xbl_sec_segs_hash_verify_exit, Start
B -     63864 - PBL, End
B -     66652 - SBL1, Start (MPM timestamp = 76616)
B -    218591 - sbl1_ddr_set_default_params, Start
D -        28 - sbl1_ddr_set_default_params, Delta
B -    227064 - boot_config_data_table_init, Start
B -    444206 - CDT Version:3,Platform ID:34,Major ID:1,Minor ID:0,Subtype:2
B -    448547 - pm_device_init, Start
B -    456745 - PM: PON REASON: PM0=0x400004000020080:0x0
B -    471420 - PM: SET_VAL:Skip
D -     17159 - pm_device_init, Delta
B -    473349 - pm_driver_init, Start
D -      2203 - pm_driver_init, Delta
B -    480033 - pm_sbl_chg_init, Start
B -    486803 - vsense_init, Start
B -    493542 - Pre_DDR_clock_init, Start
D -       313 - Pre_DDR_clock_init, Delta
B -    505413 - pm_driver_init, Start
D -      2035 - pm_driver_init, Delta
B -    511283 - vsense_init, Start
B -    524764 - clock_init, Start
B -    526695 - boot_flash_init, Start
D -      2478 - boot_flash_init, Delta
B -    533589 - Image Load, Start
D -      3016 - OEM_MISC Image Loaded, Delta - (0 Bytes)
B -    540121 - Image Load, Start
D -      4729 - APDP Image Loaded, Delta - (0 Bytes)
B -    548083 - TCSR reg value 0x10
B -    554556 - Image Load, Start
D -      2002 - Auth Metadata
D -      1500 - Segments hash check
D -     11777 - XBLRamDump Image Loaded, Delta - (49404 Bytes)
B -    569092 - usb: init start
B -    575304 - usb: VBUS High!
B -    730919 - usb: HIGH , 0x700
Logs after designating the QDLoader Port:
S - I-cache: On
S - D-cache: On
S - I-cache: On
S - D-cache: On
B - 175474464 - usb: HIGH , 0x700
B - 175562517 - usb: HIGH , 0x700
B - 175619770 - usb: ENUM success
B - 175705413 - Sahara: Hello pkt sent
B - 175707092 - Sahara: Hello Response Received
B - 175708478 - Sahara: Hello pkt sent
B - 175712315 - Sahara: Hello Response Received
B - 175715570 - handle_encryption : end
B - 176514244 - Sahara: Reset request received
B - 1765446ÿ
S - I-cache: On
S - D-cache: On
B -      5983 - bootable_media_detect_success, Start
B -      6305 - elf_loader_entry, Start
B -      7292 - auth_hash_seg_entry, Start
B -      8275 - auth_hash_seg_exit, Start
B -     36675 - elf_segs_hash_verify_entry, Start
B -     42269 - elf_segs_hash_verify_exit, Start
B -     42575 - auth_xbl_sec_hash_seg_entry, Start
B -     62661 - auth_xbl_sec_hash_seg_exit, Start
B -     62663 - xbl_sec_segs_hash_verify_entry, Start
B -     64003 - xbl_sec_segs_hash_verify_exit, Start
B -     64040 - PBL, End
B -     66768 - SBL1, Start (MPM timestamp = 76738)
B -    218726 - sbl1_ddr_set_default_params, Start
B -    227200 - boot_config_data_table_init, Start
B -    444341 - CDT Version:3,Platform ID:34,Major ID:1,Minor ID:0,Subtype:2
B -    448681 - pm_device_init, Start
B -    456855 - PM: PON REASON: PM0=0x8000028000000001:0x0
B -    471565 - PM: SET_VAL:Skip
D -     17173 - pm_device_init, Delta
B -    473495 - pm_driver_init, Start
D -      2216 - pm_driver_init, Delta
B -    480178 - pm_sbl_chg_init, Start
D -       352 - pm_sbl_chg_init, Delta
B -    486949 - vsense_init, Start
B -    493686 - Pre_DDR_clock_init, Start
D -       317 - Pre_DDR_clock_init, Delta
B -    505562 - do ddr sanity test, Start
B -    511776 - pm_driver_init, Start
D -      2034 - pm_driver_init, Delta
B -    518893 - vsense_init, Start
B -    534539 - clock_init, Start
B -    536474 - boot_flash_init, Start
D -      2474 - boot_flash_init, Delta
B -    543367 - Image Load, Start
D -      3019 - OEM_MISC Image Loaded, Delta - (0 Bytes)
B -    549898 - Image Load, Start
D -      4728 - APDP Image Loaded, Delta - (0 Bytes)
B -    558345 - PM: 0: PON=0x1:HARD_RESET: ON=0x80:PON_SEQ: POFF=0x2:PS_HOLD: OFF=0x80:POFF_SEQ
B -    562420 - sbl1_efs_handle_cookies, Start
B -    575169 - Image Load, Start
B -    582051 - Image Load, Start
D -      1497 - Auth Metadata
D -     10523 - QSEE Dev Config Image Loaded, Delta - (30208 Bytes)
B -    593236 - Image Load, Start
D -      5748 - SEC Image Loaded, Delta - (0 Bytes)
B -    601963 - pmic misc register imem initial value: 0
B -    607298 - Image Load, Start
D -      1488 - Auth Metadata
D -     19279 - RPM Image Loaded, Delta - (162540 Bytes)
B -    627042 - Image Load, Start
D -      3562 - STI Image Loaded, Delta - (0 Bytes)
B -    633547 - Image Load, Start
D -      4776 - Tiny Image Loaded, Delta - (0 Bytes)
B -    641188 - Image Load, Start
D -      1859 - Auth Metadata
D -    809847 - MPSS Image Loaded, Delta - (11675189 Bytes)
B -   1451063 - Image Load, Start
D -      1788 - Auth Metadata
D -    251855 - APPS Image Loaded, Delta - (3622788 Bytes)
B -   1702942 - Image Load, Start
D -     22197 - Auth Metadata
D -     89701 - QSEE Image Loaded, Delta - (835500 Bytes)
B -   1792971 - SBL1, End
D -   1729893 - SBL1, Delta
S - Flash Throughput, 18000 KB/s  (16326545 Bytes,  898451 us)
S - I-cache: On
S - D-cache: On
B -      7116 - auth_hash_seg_entry, Start
B -      8100 - auth_hash_seg_exit, Start
B -     36501 - elf_segs_hash_verify_entry, Start
B -     42093 - elf_segs_hash_verify_exit, Start
B -     42399 - auth_xbl_sec_hash_seg_entry, Start
B -     62489 - auth_xbl_sec_hash_seg_exit, Start
B -     62490 - xbl_sec_segs_hash_verify_entry, Start
B -     63830 - xbl_sec_segs_hash_verify_exit, Start
B -     63868 - PBL, End
B -     66656 - SBL1, Start (MPM timestamp = 76616)
B -    218622 - sbl1_ddr_set_default_params, Start
B -    227096 - boot_config_data_table_init, Start
B -    444237 - CDT Version:3,Platform ID:34,Major ID:1,Minor ID:0,Subtype:2
B -    448577 - pm_device_init, Start
B -    456772 - PM: PON REASON: PM0=0x8000024000020001:0x0
B -    471372 - PM: SET_VAL:Skip
D -     17081 - pm_device_init, Delta
B -    473301 - pm_driver_init, Start
D -      2204 - pm_driver_init, Delta
B -    479985 - pm_sbl_chg_init, Start
B -    486756 - vsense_init, Start
B -    493492 - Pre_DDR_clock_init, Start
D -       330 - Pre_DDR_clock_init, Delta
B -    505382 - pm_driver_init, Start
D -      2031 - pm_driver_init, Delta
B -    511235 - vsense_init, Start
B -    524720 - clock_init, Start
B -    526654 - boot_flash_init, Start
D -      2475 - boot_flash_init, Delta
B -    533546 - Image Load, Start
D -      3017 - OEM_MISC Image Loaded, Delta - (0 Bytes)
B -    540075 - Image Load, Start
D -      4735 - APDP Image Loaded, Delta - (0 Bytes)
B -    548021 - TCSR reg value 0x10
B -    554516 - Image Load, Start
D -      1996 - Auth Metadata
D -      1704 - Segments hash check
D -     11982 - XBLRamDump Image Loaded, Delta - (49404 Bytes)
B -    569258 - usb: init start
B -    575458 - usb: VBUS High!
B -    731337 - usb: HIGH , 0x700
B -    803134 - usb: ENUM success
B -    875625 - Sahara: Hello pkt sent
B -    877176 - Sahara: Hello Response Received
B -    878695 - Sahara: Hello pkt sent
B -    882527 - Sahara: Hello Response Received
B -    885786 - handle_encryption : end
B -   1675864 - Sahara: Reset request received
B -   17062
S - I-cache: On
S - D-cache: On
B -      8277 - auth_hash_seg_exit, Start
B -     36678 - elf_segs_hash_verify_entry, Start
B -     42273 - elf_segs_hash_verify_exit, Start
B -     42578 - auth_xbl_sec_hash_seg_entry, Start
B -     62662 - auth_xbl_sec_hash_seg_exit, Start
B -     64041 - PBL, End
B -     66771 - SBL1, Start (MPM timestamp = 76738)
B -    218728 - sbl1_ddr_set_default_params, Start
B -    227201 - boot_config_data_table_init, Start
B -    444343 - CDT Version:3,Platform ID:34,Major ID:1,Minor ID:0,Subtype:2
B -    448682 - pm_device_init, Start
B -    456858 - PM: PON REASON: PM0=0x8000028000000001:0x0
B -    471482 - PM: SET_VAL:Skip
D -     17088 - pm_device_init, Delta
B -    473411 - pm_driver_init, Start
D -      2210 - pm_driver_init, Delta
B -    480095 - pm_sbl_chg_init, Start
B -    486865 - vsense_init, Start
B -    493602 - Pre_DDR_clock_init, Start
D -       309 - Pre_DDR_clock_init, Delta
B -    505470 - do ddr sanity test, Start
B -    511692 - pm_driver_init, Start
B -    518810 - vsense_init, Start
B -    534445 - clock_init, Start
B -    536379 - boot_flash_init, Start
D -      2472 - boot_flash_init, Delta
B -    543274 - Image Load, Start
D -      3015 - OEM_MISC Image Loaded, Delta - (0 Bytes)
B -    549800 - Image Load, Start
D -      4731 - APDP Image Loaded, Delta - (0 Bytes)
B -    558222 - PM: 0: PON=0x1:HARD_RESET: ON=0x80:PON_SEQ: POFF=0x2:PS_HOLD: OFF=0x80:POFF_SEQ
B -    562324 - sbl1_efs_handle_cookies, Start
B -    575074 - Image Load, Start
D -      3766 - QTI_MISC Image Loaded, Delta - (0 Bytes)
B -    581955 - Image Load, Start
D -      1638 - Auth Metadata
D -     10666 - QSEE Dev Config Image Loaded, Delta - (30208 Bytes)
B -    593131 - Image Load, Start
D -      5758 - SEC Image Loaded, Delta - (0 Bytes)
B -    601872 - pmic misc register imem initial value: 0
B -    607148 - Image Load, Start
D -      1496 - Auth Metadata
D -     19346 - RPM Image Loaded, Delta - (162540 Bytes)
B -    626971 - Image Load, Start
D -      3548 - STI Image Loaded, Delta - (0 Bytes)
B -    633464 - Image Load, Start
B -    641104 - Image Load, Start
D -    808698 - MPSS Image Loaded, Delta - (11675189 Bytes)
B -   1449830 - Image Load, Start
D -      1710 - Auth Metadata
D -    251510 - APPS Image Loaded, Delta - (3622788 Bytes)
B -   1701363 - Image Load, Start
D -     22346 - Auth Metadata
D -     89782 - QSEE Image Loaded, Delta - (835500 Bytes)
B -   1791466 - SBL1, End
D -   1728391 - SBL1, Delta
S - Flash Throughput, 18000 KB/s  (16326545 Bytes,  897631 us)
This looping forever…
Any Ideas what to do?
Did you solve the problem? I’m in the same here…
Hi
Please try with following driver.
[Quectel_LTE&5G_Windows_USB_Driver_V2.2.4.zip]
