BG95-M5 & BG96-MA Firmware Build Request
I made the mistake of flashing my BG95-M5 EVK with this mismatch build BG95M3LAR02A04_01.003.01.003 and all works fine except there is no signaling to the Antenna as it always shows RSRP-130dbm in XCal.
May I have the proper Firmware to flash this device if it hasn’t been ruined already by this wrong build?
I also have a BG96-MA with BG96MAR02A02M1G, may I have the newest build for this EVK also?
You can also query the previous firmware version number of BG95-M5 EVK, which has two baselines R02 and R04. I need a baseline before I can match the firmware to you.
Hello, I couldn’t find this command in any of the manuals, can you provide please?
May I also request the newest Firmware for our EVK unit, a BG95-M3?
BG95 EVK
BG95M3LAR02A03_01.003.01.003
As for my mismatch unit, we are speaking of, below is all the outputs I could get:
ATI1
BG95-M3
Revision: BG95M3LAR02A04
ATI0
BG95-M3
ATI2
BG95-M3
AT+CGMI
AT+CGMM
BG95-M3
AT+CGMR
A/
BG95M3LAR02A04
AT+QAPPVER
+QAPPVER: 01.003.01.003
I have sent a new firmware of M5 to you. Please try to upgrade it and see if it can return to normal after the upgrade.
Thank you, this worked.
I am now on build
BG95M5LAR02A03_01.008.01.008
IS there any newer version for USA or is this current?
I flashed it from \BG95M5LAR02A03_01.008.01.008\update\firehose\partition.mbm
but, what are the BG95M5LAR02A03_01.008.01.008\mbn\NA files used for in this folder?
Do I flash using these for Carrier specific use maybe? I do much VZW, TMO, ATT testing and this would be nice to use if it follows some type of COPS using these files?
Perhaps these are embedded already and no need to use these?
And a latest version has been sent to you.
@tabor.tang-Q can you please share with me those differents versions firmware of BG95-M5?
BG95M5LAR02A03_01.006.01.006
BG95M5LAR02A03_01.007.01.007
Hello Alex,
I haven’t heard any response from them in a long time.
We are unsure why the lack of reply’s for updating our devices.
I tried to message them as well with no luck.
