I ran into an issue with a mini PCIE BG95-M4 trying to attach to a (private) LTE-M network 1.4 Mhz on EARFCN 9885(450 Mhz, band 31)
The hardware details
[2021-01-27_18:03:07:132]AT+CGMR
[2021-01-27_18:03:07:132]BG95M4LAR02A02
[2021-01-27_18:03:07:132]OK
[2021-01-27_18:03:13:255]AT+CSUB
[2021-01-27_18:03:13:255]SubEdition: V04
I started with a SIM on a commercial operator to see if the eMTC services were OK
[2021-01-27_17:58:18:587]AT+QNWINFO
[2021-01-27_17:58:18:587]+QNWINFO: “eMTC”,“20408”,“LTE BAND 20”,6400
Both latency and throughput were as expected.
I also investigated the GPS routines. Worked nicely!
Following a replaced the SIM for the band 31 one and the modem was unable to connect to the network. The SIM was taken from a functional MDM9205 chipset modem(other brand)
I then tried to perform a scan
AT+QCELLSCAN=8 which returned
ERROR
Using the public SIM again I was unable to perform the scan
[2021-01-27_17:58:44:139]AT+Qcellscan=8
[2021-01-27_17:58:44:139]OK
[2021-01-27_18:00:44:140]
[2021-01-27_18:00:44:140]+QCELLSCAN: -1
After switching off the GPS by AT+QGPSEND, the scan worked again.(unfortunately not anymore within coverage of the 204-66 network)
[2021-01-27_19:27:50:505]+QCELLSCAN: “eMTC”,204,04,58B2,6300,229,1A18802,-71,-7,-50
[2021-01-27_19:27:50:505]+QCELLSCAN: “eMTC”,204,08,F551,6400,30,B1310B,-78,-13,-51
[2021-01-27_19:27:50:505]+QCELLSCAN: “eMTC”,204,04,58B2,6300,276,1876501,-86,-12,-60
[2021-01-27_19:27:50:505]+QCELLSCAN: “eMTC”,204,16,40,3700,123,4B64015,-94,-11,-69
My questions;
It looks like the modem “sticks” to the last used operator. How can I release it?
Some commands I used from the BG96 AT command reference do not work. Is any firmware update needed?
Is it correct that with a running GPS, some commands are blocked?
